Old 11-25-2005, 09:03 PM
JakeDrummer JakeDrummer is offline
Send a message via AIM to JakeDrummer Send a message via MSN to JakeDrummer
Christmas Break Project
Ok so here is the deal, me and my buddy are trying to put one good car together out of three different ones over Christmas Break. These are the cars:
-'91 Civic Standard Hatchback. Motor tired and old. Body is in good shape with no rust. 256K Picked up for $200, motor died on way home after buying car.
-'87 Integra Hatch, burns oil, but runs excelent. Body rough and rusty. 267K. Black Valve Cover D16a1. Got for $150 with a brand new set of tires just put on it. Drove 10,000 Miles.
-'86 Integra Hatch, Quick and Runs Perfect. 139k. Brown Valve Cover D16a1. Car is so rusted out it is starting to sag in the middle. Body Electrical is starting to fail in rear of car. Got for $350. drove for 25,000 Miles.
Ok enough history, here is the plan. Use the Civic for the body. Pull both integra motors and every other logically usuable part of each integra and scrap the bodys. scrap the d15b1 out of the civic after scavaging for parts. Sell Civic 4 spd tranny and one of the integras motor and tranny and whatever else of the integra bodys.
Then we plan to do the imposible!!! stick the 139k D16a1 in the civic. We got a welder and a sawalls. I guess we hope to make a working car out of $700 worth of junk cars. A fairly quick Hatch for $700... I like it.
Questions:
-What ECU?? I asume the integra's will plug into the civic's harness.
-What axles?? Use the integra's??
-Which motor mount is going to have to be moved on the civic?
-What else are we missing??
I'm just trying to get some idea from you guys before we start doing this swap what we'll need. I'd do some closer looking myself but I'm in Wisconsin and its 20 degrees and snowing, AND dark at 4pm this time of year.
__________________________________________________ _____
FOR SALE - After Jan 1st:
-DOHC D16a1 - 267k, Burns oil. All there and runs excelent. Great for parts.
-'87 Integra 5spd Tranny 267k. Shifts Good.
-'91 Civic 4spd Tranny 256k. Shifts Excelent.
-'94 Integra GSR 5spd Tranny. 150K - 3rd Gear Shot, everything else shifts fine.
-Any Parts off an '86 & '87 Integra body
-Any Parts off a D15b1 motor.
To make offers, or to ask questions email me: [email protected]
94' Integra GSR - Built and Boosted.
95' GMC Sierra 1500 Z71- Business Vehicle.
89' GMC Sierra 1500 4x4 - NV4500 Donor, Mud truck.
94' S-10 - Winter Beater.
98' Jetta - Wife's Car.
81' Kawasaki LTD440
OLD/SOLD CARS: 93' Civic (Sold 124k) -- 91' Civic (Dead 300K) --
91' Civic (STOLEN) -- 92' Civic (Donor) -- 90' Caravan (Dead 227k) -- 89' Civic (Sold 289k) -- 90' Accord (Sold 265k) -- 96' Corrola (Dead 174k) -- 99' Beetle (Sold 134k)
Old 11-25-2005, 11:33 PM
Kven's Avatar
Kven Kven is offline
Re: Christmas Break Project
D16A1 engine wont fit in a ED chassis without new mounts and other mod; but im guessing you can fab something up. Its the bastard of the D-series. I also have no clue what axles but im pretty sure you can make some hybrid ones by using the ED outers and the Integra Inners on the ED shafts(Dont take my word though as I dont know for sure).
The Integra's ECU wont fit in the ED civic because the ED is OBD0, and the Integra uses a vacuum-advance distributor. Youll have to rewire the civic harness to fit the Integra ECU or find a OBD0 distributor thatll fit the D16A1 and use a Si ECU.
HondaSwap | K20A.org | EF Honda
1988 Honda CRX DX
WTB: CRX mudflaps(both front and rear)...PM me if you have some for sale!!!
Old 11-25-2005, 11:48 PM
Hybrid1990crx's Avatar
i think the motor will fit in just fine, you just have to use a d series tranny from a ed chassis. and get a obd1 dizzy. and you will have to convert the std to mpfi.
Old 11-26-2005, 12:12 AM
Kven's Avatar
Re: Re: Christmas Break Project
The D16A1 is different from other D-series. Even the transmission is different(the D16A1 transmission doesnt fit regular D-series blocks; its more related to the 86-89 accord and 83-87 prelude transmissions)
check out d-series.org , sohchonda.com , etc. for more info.
1988 Honda CRX DX
Old 11-26-2005, 12:56 AM
CrxFreak91 CrxFreak91 is offline
kven is right, but you could use the ecu out of a 88-89 integra ls it will plug-n-play with the civic .
you should be able to use the engine mount on the drivers side then mark the rest. the axles could be made into hybrids i would use the old ones and try then if it works then buy new ones and swap em out
Old 11-26-2005, 06:41 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
sell the 86 and 87 teg.
pick up a used block for the civic.
problems solved.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 11-26-2005, 07:06 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Its still not going to be quick.
Old 11-26-2005, 07:51 PM
fyi the integra's are both LS.
your right about the integra's being very accord like during the gen 1's. I'm acctully begining to think the integra axles may fit, yet i'm not sure though, as the ED civic's have those little ass hubs, like 42 tooth or whatever they are.
"sure you can make some hybrid ones by using the ED outers and the Integra Inners on the ED shafts(Dont take my word though as I dont know for sure)." ---- I guess I'll go this way if I have to. I know for a fact the 88-91 D series tranny end of the axles will go into the integra's tranny.
The Integra's ECU wont fit in the ED civic because the ED is OBD0, and the Integra uses a vacuum-advance distributor. Youll have to rewire the civic harness to fit the Integra ECU or find a OBD0 distributor thatll fit the D16A1 and use a Si ECU --- Shouldn't I just be able to use the dizzy off the civic motor or the Black top D16a1 out of the 87 Integra? The 87 is a totally different motor, has a totally differnt dizzy and seems to have more power when you drive it. hence I'm wondering if it is an early 88... thus being OBD0??
Anyhow theres a pile of jibberish for you to chew on. Thanks Guys.
81' Kawasaki LTD440
Old 11-26-2005, 07:59 PM
oh i know its not going to be blazing fast but the Integra's can keep up within about a car length of my '94 GS-R until about 70mph and then my GS-R takes off. Gap at the end of a 1/2 mile run is about 3 car lengths. Either way the ED is lighter than the Integra so it shouldn't be to bad. And my GS-R runs a 14.9, slow I know, but fast enough to play with. Those old integra's must run a high 15 with a good driver right?
81' Kawasaki LTD440
Old 11-26-2005, 08:10 PM
Figori's Avatar
Figori Figori is offline
Send a message via Yahoo to Figori
The D16A1 is a direct swap for the 1G CRX's... So, like they said, the motor won't just drop right in...Good luck, though. Keep us posted.
"Short, sweet, and to the point"
1987 CRX Si - Project Si 'RexSi'
1996 Ford Thunderbird 4.6L V8 - Plastic Intake Manifold, FTL.
2004 Nissan Sentra, 1.8s - The "s" stands for smooth....... ?
Old 11-26-2005, 08:25 PM
AF - Advisor
get rid of the tegs. throw in a d15b2 or b6 in the civic. your life will be made easier.
Old 11-26-2005, 10:24 PM
i know thats the smartest thing to do, but whats the fun in that?
81' Kawasaki LTD440
Old 11-28-2005, 09:39 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
If you can fab up the mounts for the 87 teg motor to fit into the STD then just use the electronics from it (ie. dizzy, ecu, etc.). It may not be that fast but it'll be better than a dpfi d15b2. People bash on the first gen tegs all the time but they keep right up with my CRX most of the time. GL
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 11-29-2005, 10:12 AM
Figori's Avatar
And that is why they are a popular swap with the 1G CRX guys... They are okay with the quickness, and the CRX is good with the lightness... Helps to make a pretty potent little sleeper... Mind you, it's no B18C1... But... It's cheaper...
Old 11-30-2005, 12:07 PM
doug294 doug294 is offline
Send a message via AIM to doug294
Or just try to find a cheap 1g CRX. I see them around here dirt cheap, no love for the 1g around here.
I get paid to read e-mails when I'm bored....are you bored?
http://hits4pay.com/members/index.cgi?doug684
