Go Back   Automotive Forums Car Chat > Fabrication & Tools > Other
Other Other fabricating topics.
Old 11-25-2005, 06:45 PM
cordovaass's Avatar
cordovaass cordovaass is offline
Send a message via AIM to cordovaass
cut springs
i dont know if this question belongs in this furom or not but any ways...
i have a 69 impala and i want to cut the front springs because when i bought it the rear springs were already cut.... i want to get an inch of drop, does anyone know how much to cut???
Old 12-21-2005, 05:59 PM
bigirb2002 bigirb2002 is offline
Send a message via AIM to bigirb2002 Send a message via MSN to bigirb2002 Send a message via Yahoo to bigirb2002
Re: cut springs
ya do it correctly an buy some lowering springs
Old 12-21-2005, 08:15 PM
CBFryman's Avatar
CBFryman CBFryman is offline
Banned
Send a message via AIM to CBFryman Send a message via Yahoo to CBFryman
Re: cut springs
umm...if you want to drop it 1" you usually cut about 1" off...
Old 12-26-2005, 04:05 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: cut springs
If you mark 1" while they are compressed you will get more than 1" drop. When you remove however much you remove it will lower the rate of the spring.
Old 12-26-2005, 09:52 PM
Re: cut springs
so true chamber ur the brake/suspension king
Old 12-27-2005, 01:23 PM
CBFryman's Avatar
Banned
Re: cut springs
forgot about that. yes it really depends on your current spring rate. but cutting a little less than 1" gives you a little more than 1"
Old 12-27-2005, 06:39 PM
Forunn Daberator
Re: cut springs
Fry your as usefull as a 9mm bolt.
Old 12-28-2005, 07:48 AM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
Re: Re: cut springs
-Mike
Old 12-28-2005, 07:54 PM
CBFryman's Avatar
Banned
Re: cut springs
i know
:manly sniff:
Old 12-29-2005, 11:20 PM
ummie4 ummie4 is offline
Re: cut springs
back on pt. a friend of mine lowered his car but heating the springs with a torch until they compressed the the proper height. Try it and if it doesn't work have some lowering springs or coil overs on stand by.
