Go Back   Automotive Forums Car Chat > Honda > JDM Motor & Parts info/chat
JDM Motor & Parts info/chat Discussions on Mugen, Spoon etc. Plus, info on motor swaps (b18 's, b16's h22's etc) and other JDM info!
Old 11-25-2005, 06:29 PM
Ricebrnr55 Ricebrnr55 is offline
B16A2 vs. B16B
Hey I've been trying to figure out the differences between the B16A2 here in the states and the B16B is japan. I know that the B16B has a higher horsepower and torque output, but is that because it has a different head or block or what?
Old 11-25-2005, 08:02 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: B16A2 vs. B16B
different crank, valvetrain, higher comp piston, rods, b18 block that sits 7mm taller than the b16, and camshaft.
as for bolting on wise. all b series heads and blocks are interchangable. some require a little modification. as for b16 to b16, they are all easily interchangable.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 11-26-2005, 03:18 PM
So would there be a bg difference if i swapped out the USDM head that I have on the engine now for the JDM head?
Old 11-26-2005, 05:21 PM
AF - Advisor
Re: B16A2 vs. B16B
the b16b head would definately net you some gains. like mentioned above, the b16b head is basically a regular b16 head with a port and polish, more aggressive cams, along with a better valvetrain. to really take advantage of the b16b head, you would need to up the compression on the regular b16 block. if you want to take advantage of the higher redline and revs, you would need to run a rechipped ecu (ex. hondata, uberdata, AEM, etc) or grab a ctr ecu.
as for "big".....................depends on what your definition of big is
Old 11-26-2005, 05:59 PM
Well in other words is the power gain worth the money. Where do you find just like the head because I've been looking around and all I ever can find is a complete B16B engine swap not just the head. Also whats involved with increasing the compression on the block?
Old 11-26-2005, 10:02 PM
AF - Advisor
Re: B16A2 vs. B16B
well, are you boosting or going na?
ive never seen any documented or actual results with it. i would assume the results are similar to a regular NA built b16 head with agggressive cams. you can find plenty of those with a search.
as for boost, well, the money can spent elsewhere, but, it wouldnt hurt to have an updraded head.
as for finding a b16b head being sold by itself. good luck.
