Old 11-25-2005, 05:18 PM
kmlayton kmlayton is offline
Using ethanol for 2001 Ford Taurus??
I have a 2001 Ford Taurus SES that has a Flex Fuel engine. I have been told that it can run by filling it up with ethanol. I have never done this before and have a few questions before I try it.
How does it run with ethanol in the engine?
Do I get less miles per gallon by using ethanol?
It is cheaper to purchase ethanol for fuel but is it worth it?
Old 11-25-2005, 05:48 PM
drdisque's Avatar
drdisque drdisque is offline
Send a message via AIM to drdisque
Re: Using ethanol for 2001 Ford Taurus??
Yes, if you have a Taurus FFV your car is built to run on Ethanol and Gasoline. The computer senses what the fuel is and adjust its timing accordingly. Gas mileage should be about the same, but you may notice a slight decrease in power. Its up to you to decide if its worth it or not, but I'd at least try it.
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
Old 11-26-2005, 07:15 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
You will see a significant decrease in fuel mileage. Ours dropped over 100 miles per tank on E85 Ethanol. They seem to run OK on about a 50/50 mix of unleaded and Ethanol. Ethanol also will give you some cold start up concerns also. So if you want to try it, go for it. These observations are from a fleet of 75 flex fuel Tauruses we have in our fleet. Good luck.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 11-27-2005, 05:38 PM
WHEEELS WHEEELS is offline
I Know This Is Kinda Off Topic But I Couldnt Find It Anywhere Else So Ill Try Here. 2000 Taurus 3.0 6 Leaking Coolant But Cant Seem To Find The Spot. Used Pelletized Solution No Fix.
Any Suggs?
Old 11-27-2005, 08:19 PM
hughw hughw is offline
Re: Re: Using ethanol for 2001 Ford Taurus??
Any Suggs?
Reply about coolant leak.... Usually when coolant is being lost without visible leaking its either a freeze plug possibly under another part like starter and I dont know if there are any freeze plugs there....but a good possiblity is a leaking gasket....See if you can eyeball the area along where the head attaches to the block or where the intake attaches to the heads......If you have a leak that simply evaporates away before dropping, You will see the tale tale trail of dried antifreeze running down the side of the engine...its a kind of crusty material.....
