Old 11-25-2005, 03:34 PM
happydog500 happydog500 is offline
PLENUM Intake Failure, What kind of fluid did you use?/ Both Gasgets?
At my mechanics today, we where talking about the PLENUM Failures. A comment was made that the ones that have came in to the shop, all failiers have ben with the green coolant. None so far have ben seen using the GM coolant.
If you had an intake, PLENUM failure, what kind of antifreeze did you have in it?
Thank you,
Chris.
Old 11-25-2005, 06:03 PM
auto trainy auto trainy is offline
Re: PLENUM Intake Failure, What kind of fluid did you use?
I think your mechanic is misinformed,the failures with the plenum are not from the antifreeze being used,that problem was with the lower intake manifold gaskets,the problem with the plenums was caused by deteriation of the plenum material due to heat of the egr exaust gases (check the facts).
Old 11-25-2005, 07:03 PM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
Re: Re: PLENUM Intake Failure, What kind of fluid did you use?
It depends on what year car you are talking about. I have seen intake gaskets leaking, melted plenums as well as plenums that blew apart. All the issues I have seen used Dexcool.
Old 11-26-2005, 04:03 PM
Re: Re: Re: PLENUM Intake Failure, What kind of fluid did you use?
Well its sounds like I read wrong and since you are better informed than I,what year did GM start using Dexcool and in your opinion are the engines better now than they were when all these problems started?and also does GM still use it? Thanks
Old 11-26-2005, 05:41 PM
maxwedge maxwedge is offline
A990 racer
Dexcool is not the issue with the manifolds, egr passages were poorly designed on the 3800. 1995-2003 roughly. The 3.1 and 3.4 have intake gasket problems that some have blamed Dexcool for, again not true.
Old 11-26-2005, 07:06 PM
Flatrater's Avatar
Main GM Guy
Re: Re: Re: Re: PLENUM Intake Failure, What kind of fluid did you use?
GM started using dexcool in 1995. In my opnion I don't see a difference between Dexcool and the green antifreeze but I do think that the GM engineers have lowered the standards used to build cars. Parts are not made the same and I believe they have a higher failure rate. I also think GM isn't the only company having these issues just ask any Ford tech about the 6.0L.
Also with the internet growing these issues can be found and you can find a large group with the same problems. What if I tell you that the intake melting you speak of only happens with 1% of the 3.8L engines. While I have done my fair share of intake plenums I can say that most of the 3.8L engines will never need this repair. With our site Automotive forums designed to help people with their car problems all you see is owners with problems yet people whose car never breaks you will never see them here.
As far as I know GM will continue using Dexcool until something better comes out.
Shop Foreman Buick Pontiac and GMC dealership
ASE Master Tech
ASE Advanced L1
GM Master tech
Licensed Aviation mechanic
Old 11-26-2005, 10:11 PM
popeye1 popeye1 is offline
Flatrater: I have the 2003 Series II. The antifreeze has dropper from the hot line in the plastic tank to about 1/8 inch below the cold mark. This is after about 12000 miles and eighteen months. Should i worry about the gasket leaking. The car has 26000 miles on it.
Thanks, Popeye
Old 11-27-2005, 04:16 PM
Re: Re: Re: Re: Re: PLENUM Intake Failure, What kind of fluid did you use?
Than'ks for the input and I can't agree with you more,if people would only pressure the mfrs.with the problems they see and have them listen GM would not be in the trouble there in.I didn't know there was an issue with the plenums until I got on this forum,Ive owned 3 Olds and just purchased an 01 Buick and can't complain about the 95's but the 98 was a regency and I can say that the 98 needed more attention than the 95's ever did and thank's to Consumers I'm having a hard time selling it.I hope with the upcoming GM cutbacks your not effected,good luck and thank's again. Frank
Old 11-27-2005, 05:09 PM
Flatrater's Avatar
Main GM Guy
Thanks, Popeye
When you check your level is the engine hot or cold? I perfer to check the level on a hot engine. It's isn't abnormal to lose some coolant over time. Best thing to do is keep an eye on the level, if it goes down in a short amount of time like 1000 miles then I would look for a leak. The most common place for your 2003 to leak is the throttle body to plenum area and the plenum to lower intake area. Sometimes the coolant will not puddle so look for a red or orange stain. If you see a puddle or a stain then you have a leak in that area. Replacing the gaskets isn't hard and I'm sure you could do it on your own.
ASE Master Tech
ASE Advanced L1
GM Master tech
Old 11-27-2005, 05:21 PM
Flatrater's Avatar
Main GM Guy
Re: Re: Re: Re: Re: Re: PLENUM Intake Failure, What kind of fluid did you use?
I'm sitting here watching the ship sink, the great SS General Motors is taking on water. It has already be predicted that GM will file bankrupcy within 18 months time. GM will be around a long time after this. All GM will do is kill the unions and pensions which will allow it to remain, leaner and cheaper. Also GM will shut the doors to the American factories pushing them overseas, to Mexico and Canada. If you noticed 90% of the cuts are in US plants. Right now Canada builds more GM cars then Detriot does.
All of these cuts will filter down to the dealer level, can't help not to. I have already watched my work load drop the past 3 years. But I do know that we will see GM cars for years to come and if I have to I can jump ship moving on to another line of work if I have to.
BTW with the melted intakes the way I reccomend fixing it is to replace the intake with a good aftermarket part which has a larger diameter opening for the EGR. The GM intake is cheaper but you need to replace the lower intake with GM's repair.
ASE Master Tech
ASE Advanced L1
GM Master tech
Old 11-27-2005, 08:56 PM
Re: Re: Re: Re: Re: Re: Re: PLENUM Intake Failure, What kind of fluid did you use?
BTW with the melted intakes the way I recommend fixing it is to replace the intake with a good aftermarket part which has a larger diameter opening for the EGR. The GM intake is cheaper but you need to replace the lower intake with GM's repair.
In my town the aftermarket intakes are cheaper (to the same) then the stock ones. I have access to at least three different brands of aftermarket intakes (Two local, one internet). Have you heard anyone that I should stay away from?
A lot of time it's hard for me to decide what thing to get. With different ones it's making it hard for me to figure out what one to get.
One is for $97 and says, "Re-Engineered to Prevent Common Failure Patterns, Reinforced EGR & Coolant Passage Walls for Greater Durability."
I have a mechanic who will do the job for $500-$600. Seems like it's just taking the top off and putting the new one on (I know it's a little more then JUST that). Why is it so expensive just to take the manifold off and replace it? I think I'll try and do it myself.
When I get the money, I'm going to replace it before it goes out. I don't want to have to fix anything else after my engine fills with liquid.
I didn't mean to start an argument about the different coolants. It's just an idea we had when talking. I thought what the heck, I'll post it on the forums. Thank you,
Chris.
Old 11-28-2005, 07:15 AM
stuzman stuzman is offline
BTW with the melted intakes the way I reccomend fixing it is to replace the intake with a good aftermarket part which has a larger diameter opening for the EGR. The GM intake is cheaper but you need to replace the lower intake with GM's repair.[/quote]
Flatrater,
Could you recommend an intake manifold manufacturer? It appears that there are several who claim to be the best in solving the EGR passageway problem. Also, what are your recommendations for the lower intake. Thanks for the advice!
Old 11-28-2005, 06:37 PM
Flatrater's Avatar
Main GM Guy
If all you are getting done is the upper intake then 500 dollars is too mich. The labor per most labor time guides is less then 2 hours of labor. Your mechanic must be charging over 100 dollars a hour. I do the whole job parts and labor under 400 dollars. 200 dollars for parts and 160 for labor.
The replacement isn't hard, I'm sure you are capable of doing it yourself. Frankly it takes me 45 minutes to replace the plenum, your first time might take 2 hours.
The only thing I would want in an aftermarket replacement is a larger EGR hole. An intake that is reinforced sounds like it will still melt but take longer. The key is not to have the plastic touching the EGR tube.
ASE Master Tech
ASE Advanced L1
GM Master tech
Old 11-28-2005, 10:47 PM
LeSabre97mint's Avatar
LeSabre97mint LeSabre97mint is offline
Hello
When I bought my 97 the guy I got it from said that the Plenum problem was fixed. Is the plenum something that could be removed and checked and put back on? From looking at the replacements it did look like it had an O-ring as a seal.
I'm not sure to trust the guy I got it from. The oil sensor in the pan was disconected on the oil pan. I'm wondering what else was covered up? This got me thinking if the plenum was really fixed.
Regards
Dan
Old 12-08-2005, 01:20 AM
One thing I don't understand is if the problem is the plastic melting away, why do I have to replace both upper and lower gaskets?
Can I just replace the plenum and gasket without the lower going out?
Two shops told me they wouldn't do the job unless they did BOTH gaskets.
I was told the ones GM now sells are better then what came on the cars originally. They improved them or something like that.
What do you think? A "new" GM or an aftermarket? What brand aftermarkets are good or bad? Thank you,
Chris.
