Old 11-25-2005, 03:26 PM
Melissa101 Melissa101 is offline
Flush out fluid in torque converter
I am changing the selnoid switch and replace fluids. Is it o.k. to use compressed air to flush fluid out of the converter before replacing new fluid? If not, please give suggestion.
Old 11-25-2005, 05:18 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Flush out fluid in torque converter
I wouldn't use compressed air as you could damages it. The amount of fluid in the convertor that can't be removed by dumping it out is minimal. If you are doing this with the tranny in place I wouldn't even worry about the fluid. Simply replace the fluid that you drained and the filter and it should be good to go.
