Old 11-24-2005, 09:46 PM
CCLaguna CCLaguna is offline
Send a message via AIM to CCLaguna Send a message via MSN to CCLaguna Send a message via Yahoo to CCLaguna
Lights in the vents
Anyone think this would even look attractive? Of course i'd have to hook them up to a switch, cause it is illegal and might be annoying at times, but do they even make good enough lights to handle the heat coming out and how hard would the wiring be for this?
Anyone seen/done this?
Old 11-24-2005, 10:54 PM
colinlesser colinlesser is offline
Send a message via Yahoo to colinlesser
Re: Lights in the vents
leds would be good
Old 11-24-2005, 10:55 PM
Brains!!!!!!!!
Old 11-27-2005, 01:54 PM
Of course they would be LEDS, lol :P Why go with anything else? I don't know thou, i'd have to have them somewhat back or they would be irritating while driving at night and i'm still wondering if they make bulbs and wires that can keep up with the heat and not fuck up on me.
Old 11-28-2005, 11:53 AM
Cavalier2000's Avatar
Cavalier2000 Cavalier2000 is offline
Banned
i had some in my car for a while. It was pretty neat. just make sure you use good wires techs. like don't use black tape. the heat in the vents will affect black tape.
Old 11-28-2005, 11:54 AM
you could mount them back in the vents a bit and then the would glow but not be too bright
Old 11-28-2005, 12:50 PM
Re: Re: Lights in the vents
How exactly did you hook them up and did you have to order anything special because of the heat or anything? Thanks in advance.
Old 11-28-2005, 01:06 PM
it would be easier to install them by drilling holes small enough to poke the leds into from the outside of the tubing the mount there using epoxy
Old 11-29-2005, 02:20 PM
Banned
yea i drilled a little hole and put the led in and use clear sealant to hold it all in. Don't use a glue at all it will just screw up. but it looked good for a while.
Old 11-29-2005, 06:31 PM
Where are you guys talking about drilling holes at?
Old 11-29-2005, 09:02 PM
01Cavy 01Cavy is offline
Send a message via AIM to 01Cavy
I would drill them on top of the heater vents under the dash pad. When you take the dash pad off you will see 4 black tubes that the air flows through. They are just plastic, so drilling won't be a problem.
2001 Toyota Celica GT
Check out my CarDomain at...
http://www.cardomain.com/ride/2493960
Old 11-29-2005, 11:14 PM
The 4 tubes end at the vent, or go past the vents? And if you put LEDs in the tubes, wouldn't it not allow air-flow?
Yes, i'm new to the car world. No, i'm not dumb.
Add Yourself To The Map AF Members!
Old 11-30-2005, 09:19 AM
mgless mgless is offline
that would be sweet looking just make sure it isn't stupid color and if your gonna do it i suggest putting it in every vent i have seen both and it looks pretty bad if you only put the lights in a couple vents
Old 11-30-2005, 05:37 PM
The tubes end at the vents and go back through the dash. The tubes are big and a little led won't hurt the air flow.
