Go Back   Automotive Forums Car Chat > Mazda > 323/Protegé/Familia/Etude/Allegro
Old 11-24-2005, 09:36 PM
jameshergitz jameshergitz is offline
Squeeking at startup
Hi I would appreciate if anyone could help me diagnose a problem i am having.
I have a 1997 Mazda Protege, 1.8L 4 door automatic.
During startup, especially during cold days, there is a squeek someone under the hood. I replaced to engine belts. But i did not do the timing belt or alternator belt.
Also, the same squeek occurs when i turn the wheel when idle to the very most extremes.
Thanks for any help in advance.
James.
Old 11-25-2005, 08:29 AM
Flash75 Flash75 is offline
AF - Advisor
Re: Squeeking at startup
Did you check the alternator belt for tightness? Also make sure the belt driving the power steering pump is properly tightened.
Clifton
Old 11-27-2005, 08:36 PM
Re: Re: Squeeking at startup
Thanks for the excellent reply! I really appreciate your help. I looked at the alternator belt and seems to be worn. The second part i will check at the same time. Great feedback. Thanks again.
[quote=Flash75]Did you check the alternator belt for tightness? Also make sure the belt driving the power steering pump is properly tightened.
Clifton[/QUOT
