Old 11-24-2005, 09:11 PM
jag0034 jag0034 is offline
Angry Radiator Fan
I have a 97 Cavalier 2.2 Liter Engine.OHV and I have a problem w/ the radiator fan not cutting on. I can put a piece of wire where the relay is supposed to be and it cuts on but it stays on even w/ the car off, so if i forget to pull it, then i need a jump b/c the battery dies. i have replaced the relay and also replaced the fan itself but it still does not cut on. the temperature gauge on the console works fine and indicates when it gets hot. PLEASE, SOMEONE HELP! it's driving me nuts!
Fredo
Old 11-25-2005, 12:21 AM
Xx ReasoN xX's Avatar
Xx ReasoN xX Xx ReasoN xX is offline
Send a message via AIM to Xx ReasoN xX
Re: Radiator Fan
What you could do is rewire the fan and running it thru the firewall into your fuse box and wrap it around your ignition switch that way the second you turn the key the fan comes on.
Old 11-25-2005, 12:24 AM
jakegday jakegday is offline
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
how about the sensor (i forget what its called) but it tells your computer the temperature of your coolant, and once that coolant gets too warm, the computer "tells" your radiator fan to turn on, if that sensor is bad, your computer wont know the temperature, and it wont know when to turn on your fan
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
Old 11-25-2005, 10:14 AM
does your temp guage still work? i just did a little research and if your temp guage does still work, you can forget everything i said in that last post
Old 11-25-2005, 11:40 AM
Ryan066 Ryan066 is offline
Re: Radiator Fan
I got the opposite problem . mine cuts in too early, it kicks in when the hoses are not even pressurized :/ my guage at max temp is half-way... i replaced the t-stat and just serviced the cooling system and it still does it.. i got good heat too.
edit/
im going ot read up about it.. if I find anything usefull ill be sure to let ya know
Old 11-27-2005, 12:24 AM
Cold_Silence's Avatar
Cold_Silence Cold_Silence is offline
Send a message via AIM to Cold_Silence Send a message via MSN to Cold_Silence
Re: Radiator Fan
Whats with these damn rad fans, mine wont work either, i dont wanna pump a bunch of money into it if it wont even help the problem, like sensors, thermo, coolant service etc..
The New Ride!! 2002 Cavalier Coupe..
Originally Posted by noshun
It's a lovely 2200, but got about as much poke as my grandma with no fingers.
www.cleanstartsolutions.com
Old 11-27-2005, 08:26 AM
airwave_assassin airwave_assassin is offline
Send a message via AIM to airwave_assassin
Re: Radiator Fan
i'd just run it to through the firewall and to a toggle switch. this way you can turn it on and off when you need to.
Old 11-27-2005, 08:11 PM
Re: Radiator Fan
Sorry, newb question, what exactly is the firewall? Where is it located. It is on the radiator correct?
Old 11-27-2005, 08:13 PM
Re: Radiator Fan
no
the firewall is between the gas pedals adn the engine. dunno why its called that but hey, its where you run all your electrical through to teh car.
Old 11-27-2005, 08:16 PM
Re: Radiator Fan
Between the gas pedals and the engine? the throttle body u mean? So it just connect all the wiring? Im thinking of connecting the fan wires to somethin like they said so it runs normally. Which wires wud i need to use to do that? Thanks
Old 11-28-2005, 09:33 AM
Re: Radiator Fan
the wiring doesnt connect to anything there. its just the place where the wiring enters the car.
Old 11-28-2005, 09:17 PM
Re: Re: Radiator Fan
the firewall is the big peice of metal that seperates the engine bay from the passenger/driver comparment...
what hes saying it to run a wire directly to the fan that is hot (has power to it) when the ignition is turned on. and run the wire through the firwall (where all the other wiring harness goes through from the battery, just to hide it so it doesnt go through the window... etc..) and connect a switch so you can turn it on when it needs to be on...
but if you dont have an idea how to do so I wouldnt bother.. fix it right.
