Old 11-24-2005, 08:48 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Tires, rims, traction and drag racing. Suggestions?
I have been thinking a lot lately about tires, wheels, traction, and how they all affect drag racing. When I get my DSM, eventually I want either a SBR 50 or true 60 trim, depends on how power hungry I get (ideally 500hp, maybe not, but for sure well into the 400's). Anyway, it will be a 1g AWD. First off, rims. I was thinking about 15" rota slipstreams for track rims. The only thing is they are like 6.5" wide. What would be better, having the smaller rims, but narrower tires, or the taller rims, but wider tires? Is the traction of a wide tire worth the extra weight? What about racing tires? Are drag radials needed for an AWD car? If not, I was going to just get the slipstreams and some good street tires, but if drag radials are needed at 450+ hp, then I was going to get either two sets of slipstreams or one set of slipstreams and one other set (probably the 16" ones of a 2g). What do you guys think?
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 11-24-2005, 09:51 PM
Whathits14 Whathits14 is offline
Re: Tires, rims, traction and drag racing. Suggestions?
wider is better for traction....you should be able to get some rims made just for drag that will be small and wide. Drag radials are almost always better than normal tires, but if you are shooting for 400+HP some radials would make a difference.
Need a GOOD 6-bolt engine?
http://www.totaljdm.com/?id=19334
'95 Talon Tsi
EVO III GT, supporting mods, not running
Brand new never opened, walbro 190LPH fuel pump for a 2g $65 shipped.
Old 11-24-2005, 10:22 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
I think tires would make a small difference. But I would see slicks being more practical for a fwd or rwd as opposed to an awd vehicle. If you were putting some serirous power to the ground and your tires started slipping in an awd launch then I would think about tires.
1991 GSX 2.3 Stroker
Old 11-24-2005, 11:21 PM
Thor06's Avatar
Jizzed In My Pants
Yeah, I didnt want to shell out lots of $$$ for some of those short and wide rims though. OH MAN guys, I might be getting my own DSM soon! I have my 01 Cavalier that my brother is going to buy soon, so I just started looking for a good 90-91 DSM. I found one! But I wont tell you where so you go get it yourself! Anyway, its a white 5 spd with low miles and all original. I am going to call those MF's tomorrow and see if its still for sale, if so its home to the parents to explain to them that I will be getting a POS money pit like Mikes car and after much debating and telling them how much it will be a reliable college car ( yeah fuckin right) I will be off to Location X to pick up MY OWN FUCKING DSM! AHHHH! It'll still be parked for a while while I fix a few little things (if it needs it), clean the shit out of it, and star modding. Oh man guys I need to go to bed, but I dont know if I am going to sleep tonight. Do any of you have a bouncing leg when you are sitting down? Well, both of mine are going crazy right now. Probably tomorrow or the next day I am going to talk to my dad and I'll imediately run down stairs to let you all know what is going to happen.
Old 11-25-2005, 02:42 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
you won't need drag radials on an awd for quite awhile, it'll be hard (if not impossible) to spin all 4 tires even with 400-450hp. i'd just go with a nice light set of say..17's with a nice wider tire like 235's or something.
95 Talon TSI AWD
97 Eclipse GST
Old 11-25-2005, 10:08 AM
scottsee scottsee is offline
Send a message via AIM to scottsee
Tires make a large diffrence at the track. Changing the diameter will effect the gear ratios, odometer, ride height wich will effectivly chagne your verdical weight transfer durring lanches.
The more width you have though the better off you are. More contact paths for all that HP/TQ to find its way to the ground.
DSM geek
Old 11-25-2005, 11:31 AM
northriverflames northriverflames is offline
Send a message via MSN to northriverflames
I agree with scottsee....although awds do have some traction problems, they arent near as bad as a fwd or a rwd, but if i launch my awd too hard the back end will come loose on the track and give a slight fishtail. In my opinion i wouldnt worry about tires and rims until your running 12s/11s on stock tires...
P.S. unless you have a lsd int he front your never going to spin all 4 tires, you can spin three but not four!
2000 Chevy Silverado 1500 4x4 Extended Cab.
1996 Pontiac Sunfire GT 5 Spd.
1992 Plymouth Laser RST AWD 5 Spd.
Old 11-25-2005, 02:53 PM
Thor06's Avatar
Jizzed In My Pants
The LSD is only in the back? Gay! Oh well. Ok, so should I try to find a good compromise, say 16-17's?
Old 11-25-2005, 06:15 PM
If there was a lsd in the front you would be replacing axles alot...the locking of the axles would not work since the tires spin at different speeds while cornering. Therefore there is no lsd in the front. You can put one in the front but it is not recommended unless your car is strictly for the track!
Old 11-25-2005, 07:35 PM
Saleen85 Saleen85 is offline
Send a message via AIM to Saleen85
You can get some nice Weld wheels, like the domestic guys run, in a 15x7 or 15x8, specific for drag racing. Very light, and wide enough for some wide sticky tires.
As far as spinning all four, it can be done. at 20psi, all 4 of mine spin, and I don't have an LSD in the front. I've got more than one witness, and more than one occassion at the track. With the current cold weather, I am spinning at 15psi. The poor man's LSD in the front, is a welded viscous coupling.
Rob
1990 Talon TSi AWD Yea, it's stock
1991 Talon TSi AWD
1991 Eclipse GSX
Old 11-25-2005, 07:36 PM
Re: Re: Tires, rims, traction and drag racing. Suggestions?
You're thinking of a spool. There is a difference between the two.
1991 Talon TSi AWD
1991 Eclipse GSX
Old 11-25-2005, 07:50 PM
Thor06's Avatar
Jizzed In My Pants
I just thought that they would put a LSD front and back, I dont really care that much. If I wait until 11's for drag tires, I'll be waiting a while so maybe I will try a some short and wide rims (like the Weld's previously mentioned) and put some decent street tires on. What do you think? Should I stagger the rims, like maybe 7" wide up front and 8" in the back? How wide should I go?
Old 11-25-2005, 09:39 PM
i1nk83 i1nk83 is offline
Send a message via AIM to i1nk83
the 3kgt/stealth's come w/ 16x8's. they are kinda heavy but you can put a hella big tire on there. they are fairly common an cheap. that might be a choice for yah.
1990 mitsu eclipse gsx
16g
550's
burned eprom chip
2g mas
3" turbo back custom exhaust
port&polished head, turbo, exhaust mani
mml headgasket
b.s. elimination
centerforce df2
unorthodox crank pulley
autometer boost , a/f
hallman es mbc
homemade fmic and piping
relocated battery lower in engine compartment
purty candy red valve cover
stripped interior
couple of random guages
man this is a big list of nothing special......gotta work on that
50trim in the works
Old 11-25-2005, 10:27 PM
Thor06's Avatar
Jizzed In My Pants
Oh fuck yeah! I'll definately hit that up thanks man. The car I am looking at has the shitties looking rims ever. They are the swirl ones that came on some Talons. They look ok, but these are rusted and shitty looking. Thanks man I appreciate it.
Old 11-28-2005, 12:09 AM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
So did you get the car?
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
