Old 11-24-2005, 02:41 PM
mybigredford mybigredford is offline
low oil pressure
have a 92 s-10 with the 4.3 vortec. oil is full but have low oil pressure on the gauge, which i got the digital dash out of a different blazer and the rpm gauge doesnt really work all the time either , could this just be a problem with the used digital gauges or what and ideas?
Old 11-24-2005, 08:35 PM
BlazerBoyLT98's Avatar
BlazerBoyLT98 BlazerBoyLT98 is offline
Send a message via AIM to BlazerBoyLT98 Send a message via Yahoo to BlazerBoyLT98
Re: low oil pressure
Right off the bat I would say your problem is the digital dash, but it could be worse. I am thinking it is the dash and something is not connected properly
2002 Pontiac Gram Am
K&N Air Filter
Mobil1 5W-30 Extended 15K
2 JL Audio 12" Subs Sealed JL Audio Box
Coustic 400 Watt Class D Mono Amp
Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner
Polk DB750 6.5" all around
Yankees Suck!!!!!!!!
Old 11-24-2005, 08:43 PM
DINO55's Avatar
DINO55 DINO55 is offline
Maybe a bad oil pressure sending unit? Very common problem on these trucks.
1998 BLAZER LS Vin-W 4Dr 2wd
2004 Cavalier LS 4Dr 2.2 Ecotec
"Good Part's ain't Cheap--Cheap Parts ain't Good"
Old 11-24-2005, 08:52 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
If you had low pressure the engine would knock.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 11-24-2005, 11:48 PM
wolfox's Avatar
wolfox wolfox is offline
Send a message via Yahoo to wolfox
Yep, extremely low pressure would not allow the lifters to operate properly, and self-adjust lash out of themselves. This makes a *terrible* racket. I would go with Dino55 and BLT on this one. The sending unit is not expensive, but it is a pain in the butt to get swapped out. If and when you swap it, run three turns of teflon tape around the threads. I also would check to make sure that the harness was in good shape that plugs into the back of that sensor, as a high resistance connection could show lower than average pressures.
Old 11-25-2005, 12:35 AM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
Different years of digital dashes, have different pin-outs, or connections at the back, I am not sure of the year to year differences, but there is differences.
