Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 11-24-2005, 02:32 PM
defman's Avatar
defman defman is offline
Ls/vtec info
I have a 94 honda civic with a jdm b18b equipped with a b16 tranny. I previously had a jdm b16a swapped in the car and still have the motor. Im almost positive the rings in the b16 are shot, hense alot of N2O...
Ive found numerous guides on the net of how to perform head swap along with a list of the needed parts... but I am still a little weary about the bottom end of the b18b. Will arp rod bolts provide adequate protection from the 8000 rpm revs? What is the real problem with the bottom end? Would better rods, after market or from a b series vtec motor provide a reliable solution? Is there a cost effecient solution?
Old 11-24-2005, 03:21 PM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Re: Ls/vtec info
there was a good LS/VTEC write up a little while back....if you search you should be able to find it.....or if Ace finds this thread, he has an LS/VTEC and seems to know a lot about it....
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 11-24-2005, 05:47 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: Ls/vtec info
http://www.sportcompactcarweb.com/tech/0411scc_hybrid/
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 11-25-2005, 12:40 AM
defman's Avatar
just to check
Thanks for the help, I looked up all of the ls/vtec threads and Checked out the web page... Just to make sure, because it seemed everyone had different opinions...
I take my b18b block, put my b16a head on there, and im prolly going to have my head shaved slightly, but using the golden eagle conversion kit and dowl pins, If I put in some arp rod bolts will that be enough for the bottom end to hold 8000 rpms? and also, using all the stock ls internals, would you consider this to be a safe/reliable combination... I really only need this motor to run for about 8-9 months, or untill i graduate from college.
Old 11-25-2005, 10:44 AM
Schister66's Avatar
AF -Advisor
Re: Ls/vtec info
don't build it to just run for 8 or 9 months...that's just asking for trouble!
Old 11-25-2005, 12:11 PM
JustaSolVTEC JustaSolVTEC is offline
Send a message via AIM to JustaSolVTEC
Re: Ls/vtec info
you'll also need to plug on the oil passage in the head and run an external oil line.
my LS rods with ARP rod bolts hold the 11.6:1 CR-VTEC just fine. and that's revving to 8500rpm.
Old 11-25-2005, 01:51 PM
Ace$nyper's Avatar
Ace$nyper Ace$nyper is offline
Banned
Send a message via AIM to Ace$nyper Send a message via MSN to Ace$nyper Send a message via Yahoo to Ace$nyper
Re: Re: Ls/vtec info
Best thing said. Do it right worse to worse it'll last longer then needed.
When you make somthing half ass you'll get that out of it.
Justasol what are the specs on yours?
If planning to run LS guts get the ARP bolts well worth it.
Old 11-25-2005, 05:09 PM
defman's Avatar
Ok last question, If I have my head shaved .040 of an inch, and use a 2 layer head gasket, i wont have to work about the piston hitting the head right?
Old 11-25-2005, 05:14 PM
defman's Avatar
the reason i ask, I found a compression calculator from one of the past threads and with my setup, the piston to deck clearance is -0.026
Old 11-26-2005, 11:05 PM
Krzintegra95 Krzintegra95 is offline
dont shave your head with a thin head gasket .. the LS motor already dont really have the valve reliefs for vtec cams ..keep your stock head gasket and dont mill it..just put some mild cams in it like the itr or ctr cams .. and if you are strap for cash .. you can polish the intake and exhaust ports yourself .... use arp head and rod bolts and if you want to golden eagle also makes a block gridle like the gsr and itr for you .. i didnt use that on my crvtec because i dont beat on my motor ..if i race maybe ill take it to 7800 rpm's buyt i dont need to other thatn that if you drive in the 5000 rpm range mostly like me then dont run it just the arp head and rod bolts .. my motor is still strong and i have 2000 miles on it ..i know its still to early to tell but between now and dec 15 i know im going to put another 2000 miles on it ..im driving from NY to FL ^^ ..and i drive to canada alot ..thats 140 miles for 1 trip .. so just dont beat on your motor and it will be cheap
