Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 11-24-2005, 11:52 AM
unknownluder69 unknownluder69 is offline
jdm h22a1
ok i have a 4th gen lude with the h22a1 and it has like 136k miles on it so i have decided to replace the engine b4 tricking it out. i just wanted to know besides the 30 hp difference wat other differences are theree between the jdm version and the usdm model? will all the parts that fit the usdm model fit the jdm model just as well e.g. turbo kits or cams...?
and how easy is it to swap? or is it just a drop in??
thanks
Old 11-26-2005, 09:01 PM
honda_racing101's Avatar
honda_racing101 honda_racing101 is offline
Send a message via AIM to honda_racing101 Send a message via MSN to honda_racing101 Send a message via Yahoo to honda_racing101
Re: jdm h22a1
Search.
dSoc member #67
1995 Honda del Sol EG2 VTEC Milano Red. RIP :crook:
1994 Honda del Sol EG1 S-full VTEC conversion.
Buy my Del Sol parts!!
Old 11-27-2005, 05:39 AM
jakalminch jakalminch is offline
Re: jdm h22a1
Well i have a 95 srv and i have to replace the motor aswell. Anyway im currently waiting for my jdm should be here soon, from what i've researched its only a 10 hp difference because of better compression. None of the sensors, exhaust manifold, distributor or any of the externals that come with the jdm can be used with your car. So basically strip it down to the head and block and drop it in and attach all the sensors and ecu from your original engine. everything should be fine but i'll have a little more info after it's all said and done.
Old 11-27-2005, 02:31 PM
iVteC_PoWeR iVteC_PoWeR is offline
Send a message via AIM to iVteC_PoWeR
Re: jdm h22a1
basically jdm has a slight bit higher compression which is why there is the 10hp difference but if you want to turbo the USDM h22 has a little lower compression so it might be a better platform to start...plus USDM is cheaper
Old 11-28-2005, 04:14 PM
integrase integrase is offline
Send a message via MSN to integrase Send a message via Yahoo to integrase
Re: jdm h22a1
either way if u wanna turbo it u gonna have 2 do the block trust me. and u gotta do it all only thing u can save money on is eagle rods vs crower but i prefer crower and prob je pistons and a f22 crank if u want it 2 be a 2.45 instead of 2.2 but if u want turbo u can throw a gasket on it and watch it blow in a few months but fully building the block will be 3000. do that then work on the turbo. then the head. stick with stock cams but u need the backbone of the motor which is the built block. if u gonna go turbo just keep the usdm and make sure head is good or buy a doner block and build that as u get the money and get a head if u can. but when it comes 2 a h22 espically u get wat u pay 4. ps they do good with a 75 shot and as well ive seen a lude go mid-low 11s on the motor alone. decide wat u gonna do 1st
Old 11-29-2005, 07:08 PM
Re: Re: jdm h22a1
USDM isn't usually cheaper.
dSoc member #67
