Old 11-24-2005, 11:03 AM
nick bamberger nick bamberger is offline
Seafoam
I wasn't sure where to post this, so I put it here.
Would it be OK to u se SeaFoam in 1 cyl. engines like 4 wheelers and such without harm?
Old 11-24-2005, 11:40 AM
Andydg Andydg is offline
Re: Seafoam
Should be ok, but I guess it depends on which SeaFoam product you're using.
Old 11-25-2005, 04:18 PM
alfonso2501 alfonso2501 is offline
Send a message via AIM to alfonso2501
I’ve heard lots of good stuff, supposedly it’ll clean the piston tops. You’re suppose to have it sucked in thru the brake vacuum line then shut off the car for an hour & when you restart it, it’s going to create a whole lot of white smoke out the tail pipe. While I hear lots of good stuff about it still scares me to try it because I’m worried about hydro locking my engine. Also, now that I think about it, I’m worried about my catalytic converter. But like I said I hear lots of good stuff about it. Maybe I'm just worry wort.
If you do it tell us how it goes, & check your sparkplugs after.
Old 11-25-2005, 04:23 PM
Jet-Lee's Avatar
Jet-Lee Jet-Lee is offline
Banned
Send a message via AIM to Jet-Lee Send a message via Yahoo to Jet-Lee
Re: Seafoam
wrong forum?
on topic:
I use it ever other month. I stick the brake booster line in till it sucks out about half the bottle, then jam it in there and stall it out. Let it sit for 15 minutes or so and go for a fun(smokey) drive.
I don't imagine it would hurt a 1cyl engine at all. Make sure you suck enough up to stall it out, so it doesn't burn it all away before you can kill the engine.
Old 11-26-2005, 12:59 AM
WickedNYCowboy's Avatar
WickedNYCowboy WickedNYCowboy is offline
Send a message via AIM to WickedNYCowboy Send a message via Yahoo to WickedNYCowboy
I hesitate putting anything into the engine that isn't put there by the factory. As for your cat after it runs well go for a VERY HARD drive it will help clean the cat out.
Evan
Support your local volunteer fire department
My Rides:
2003 Ford F-350 Long Horn Hauler
Others:
1999 Toyota Camry LE V6-Dad
2004 Chevy Tahoe Z71-Sister
2004 Toyota Camry LE V6-Mom
Old 11-26-2005, 01:25 AM
SiGNAL748's Avatar
SiGNAL748 SiGNAL748 is offline
Send a message via AIM to SiGNAL748 Send a message via MSN to SiGNAL748
Re: Seafoam
You're gonna need to pour a lot of it in to even come anywhere near hydrolocking your engine.
and by a lot I mean liters and liters of it.
EDIT: and seeing as this stuff burns so quickly, I would imagine it'd be nearly impossible to hydrolock with it, even if you tried.
Old 11-26-2005, 01:11 PM
Re: Re: Seafoam
I agree. Today's engines are extremely hard if not impossible to hydrolock.
Evan
My Rides:
Others:
Old 11-28-2005, 08:13 AM
Jet-Lee's Avatar
Banned
Re: Seafoam
hydrolocking is seizing the engine using water. Water isn't combustible, which makes hydrolocking possible. Seafoam is combustible, so you can't hydrolock(waterlock) your engine, just stall it out.
