Go Back   Automotive Forums Car Chat > GMC > Sonoma | S-15
Old 11-24-2005, 10:35 AM
noma96 noma96 is offline
removing factory radio help
i am having trouble removing the dash on my 96 sonoma ext cab. i can get it unhooked but cannot get it over the gear selector ive tried removing it in every gear
Old 11-24-2005, 02:26 PM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: removing factory radio help
You need to drop the knee bolster, the remove the 2 15mm nuts on the column bracket, allow the column to rest on your seat, you can than move the trim panel out of the way.
Old 11-26-2005, 06:38 AM
rlith's Avatar
Any luck?
Old 12-02-2005, 04:30 PM
Originally Posted by rlith
Any luck?
naw man the bracket is welded to the column is there another way
Old 12-02-2005, 05:40 PM
rlith's Avatar
Re: Re: removing factory radio help
Yes it's welded to the column, on each end of the bracket is a 15mm nut, remove those nuts and drop the column!
Old 12-02-2005, 05:44 PM
Re: Re: Re: removing factory radio help
the column wont drop becasue the bolts are stationary and i cant move the column up off of the bolt can you send me a picc or something cause i cant get it. thanks
Old 12-02-2005, 06:17 PM
rlith's Avatar
the bolts are stationary, the nuts aren't, once you remove the nuts, if the column doesn't fall, simply put weight on top of the steering wheel and it will drop
Old 12-02-2005, 06:20 PM
hey man ive tried that already but the blots are to long and when i put weight on the steering wheel it just pushes down on the bolts and doesnt come off.
Old 12-02-2005, 07:06 PM
rlith's Avatar
the bolts won't come off... the nuts will. I hope to heck you removed the knee bolster...
Old 12-02-2005, 07:11 PM
i know the nuts come off but i still can get it off the bolts what is a knee bolster is it the panel right under the stering wheel. can you send me a pic cause i dont know if where talking about the same nuts and bolts thanks alot man
Old 12-02-2005, 07:16 PM
rlith's Avatar
yes, the knee bolster is under the steering wheel... I don't have a pic of it but it sounds like you've got the nuts off the correct area. Once the nuts are off the brackets, the only thing that could be holding it up is the knee bolster. Use a t30 torx bit to remove the front screws and a 7mm to drop the lower panels, that will drop the steering wheel enough.
Here is a pic at least with an arrow pointing to the knee bolster
Old 12-06-2005, 04:19 PM
thanks man ill have to try that again cause some other guy told me to put it in 1st then slide the dash off i tried that and got it almost off but it was catching on the 4way light switch long story short i broke it off and im fucked now cause the lights just stay on so i think ill try your way again if all else fails im just going to pay a professinal to do it casue so far its cost me alot of money.
Old 12-06-2005, 04:38 PM
rlith's Avatar
You're gonne need this...
http://www.blazinlow.com/forum/showt...azard%2BSwitch
Old 12-06-2005, 05:16 PM
Re: Re: Re: Re: removing factory radio help
thanks alot man that help hahaha at least im not the only on who has done this
Old 12-06-2005, 05:20 PM
rlith's Avatar
Tried to tell ya, drop the knee bolster and lay the steering wheel in the seat...How the hell did you get the bracket nuts off the steering column without removing that!?
