94 Blazer keeps draining battery, won't stay running..Help, please
My 94 Blazer won't stay running. It keeps draining the battery, I had the alternator replace (which everyone said was the problem) but it will only run a little while and then you have to boost it off again. I just can't afford another mechanic bill (alternator replacement was over $200 and no fix).
Please tell me it is something a lady can fix, lol. |
Re: 94 Blazer keeps draining battery, won't stay running..Help, please
Welcome to the board.
The job isn't even a 1/2 hours work for most alternators, so the labor isn't the issue here. I can't say for sure, but I'd be leaning towards the starter going. I don't knw why, but some starters just kill the battery when they are shot. And yet they still start the car like normal when they have the juice. If it is the starter it's a bit of a pain, but we'll tell you how to replace it. |
I agree with Overboardproject...
Also, How Old is your Battery? Are the Battery Cables clean? Did anyone load test it? you said "I had the alternator replaced (which everyone said was the problem) but it will only run a little while and then you have to boost it off again". Did they (machanics) test the Charging system to determine the Alternator was bad. A dead cell in a battery will drain all the power out of it and act the same way as you describe...
1998 BLAZER LS Vin-W 4Dr 2wd 2004 Cavalier LS 4Dr 2.2 Ecotec "Good Part's ain't Cheap--Cheap Parts ain't Good" |
1995 Factory Blazer Service Manual for sale, PM if interested. |
Thanks for all the advice! Had the battery tested and was told it was good but when I bought the blazer the battery had to be charged and had very little water in it but I thinking like you, it still may not hold a charge. Just got off work but will try a new battery first, if it doesn't solve the problem I'll be back for help with the starter.
Again thanks so much for the help. I knew I came to the right place!! I will keep you posted and wish me luck
