Old 11-23-2005, 11:58 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
Ac removal
Okay. So my compressor shit a while back and I don't feel like paying to get a new one because it's fucking crazy expensive. Anyway. I know that removing it won't take that much weight off the car but I figure I'm not using it might as well junk it free up some room in the engine bay. Anyone know any good guides to remove this? And what else I can remove that is part of the whole ac system?
1991 GSX 2.3 Stroker
Old 11-24-2005, 12:50 AM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Re: Ac removal
Actually removing the condensor will help with the airflow to the radiator, i think thats the biggest advantage of removing the ac. Just follow the lnes off the compressor and take em al out.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 11-24-2005, 12:52 AM
defiancy's Avatar
Re: Re: Ac removal
I honestly have no idea what a compressor looks like.
Old 11-24-2005, 01:19 AM
ez1286's Avatar
Re: Ac removal
It'sthe only thing that's belt driven that is behind the engine. You might have to take of your radiator to get the condensor out, i'm not too sure cause i pulled mine when i put my front mount on.
Old 11-24-2005, 01:26 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: Ac removal
You have to take off the radiator to get to the condenser out. It allows for alot better airflow to both the radiator and the engine. You're removing a huge blockage when air comes in through the front grill. Been looking at doing it to mine.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 11-24-2005, 01:29 AM
defiancy's Avatar
Re: Re: Ac removal
Am I going to have to plug anything when I remove it? like feed lines or anything?
Old 11-24-2005, 01:31 AM
ez1286's Avatar
Re: Ac removal
No, I'd do it outside cause the R134a will leak out when you cut or take off the lines. But its al self contained so you don't have to block and lines going to the rest of the car.
Old 11-24-2005, 01:40 AM
defiancy's Avatar
Re: Re: Ac removal
Rock on, thanks alot.
Old 11-24-2005, 01:43 AM
ez1286's Avatar
Re: Ac removal
No prob, good luck.
Old 11-24-2005, 07:52 AM
Gsx_hooptie Gsx_hooptie is offline
This is what I'm best at: rip and pull. One line leads to another.
You'll need to depressurize the system first. Or, at least, it's less messy. There's a schrader valve on the top right of the bay with a blue screw top on it. You can recover the stuff rather than venting it if you like your ozone layer. Shops will do it, sometimes for free. If not, just use a flathead screwdriver. The condenser, IIRC, is a silver canister to the bottom right of the bay. You can clean up some of the mess of the engine bay by removing the AC lines. Rip and pull. Some of them are hard to access and may not be worth it. Your call. A lot of the AC crap for weight reduction is also located under the dash. Good luck.
Edit>> Couldn't tell my left from my right.
I used to own a DSM.
Originally Posted by Anon.
Capitalization is the difference between, "Helping your uncle Jack off a horse," and, "Helping your uncle jack off a horse." The comma is the difference between, "Eats shoots and leaves," and "Eats, shoots, and leaves."
Old 11-24-2005, 10:20 AM
sganc4life_4 sganc4life_4 is offline
Send a message via AIM to sganc4life_4
Re: Ac removal
Yea the heater core will be under the dash, that would be good to remove too, maybe a pain in the ass tho.
95 Eclipse GS-T
6 bolt built block - shooting for 450 hp..very doable
Currently:
A lot, check progression thread - updated 3/27/10
Estimated completion date:
Soon lol
Old 11-24-2005, 10:47 AM
Turbodog97's Avatar
Turbodog97 Turbodog97 is offline
Just a Neon
But what about the actual condensor itself. Wouldn't you have to remove the rack&pinion or driver's cv axle to get to it? I've tried to remove it before but it's so far up in there
05 Srt4
Agp 3147 w/supporting mods
97 Mx-5
T28, hks man, ebay int/pipes, rfl bov, xtd 6 puck, 3" magnaflow, msd timing box,
Old 11-24-2005, 11:09 AM
Re: Ac removal
I think your able to slide it straight up and out from what Ive read. Its a tight area but its been done
95 Eclipse GS-T
Currently:
Soon lol
Old 11-24-2005, 11:21 AM
Turbodog97's Avatar
Just a Neon
Anyone know where the bolts are holding it to the car? I just finished looking at it and there seem to be so many bolts attached to it I wouldn't even know where to start...
05 Srt4
97 Mx-5
Old 11-24-2005, 12:28 PM
Turbodog97's Avatar
Just a Neon
OKay I just got the damn thing dislodged but I can't get it out of the engine bay. Either go down by removing the cv axle or go up by removing basically everything. I don't know what to do!
05 Srt4
97 Mx-5
