Old 11-23-2005, 10:44 PM
Apexi_N1 Apexi_N1 is offline
CSC on clear & chrome part?
Did search but couldn't come up with the answer. I would like to remove some paint on the windows/wheels, would CSC demage the finishing on those clear/chrome parts?
Sorry if it has been covered before, pls point me to the right direction.
thanks.
CS
Old 11-23-2005, 10:59 PM
FranKey's Avatar
FranKey FranKey is offline
Re: CSC on clear & chrome part?
i stripped chrome with no problem with Csc but i doubt clear parts would survive... try with a spare piece maybe?
Old 11-23-2005, 11:03 PM
Re: Re: CSC on clear & chrome part?
so the chrome actually came off? (damn, would've been nice to if the chrome stay on the wheel! )
Old 11-24-2005, 01:02 AM
daklunk's Avatar
daklunk daklunk is offline
Yeah, CSC will strip both the chrome and clear primer coat off in about 15-20 minutes, a little longer for different types of paint. Not sure about clear... CSC is can be either a blessing or a curse in my experience.....
Your best bet would probably be to test a piece you don't care about and see how it fares. Some of the other members no doubt have solutions for you. Good luck.
Slow down, dear, you're scaring the dog...
1:1 ride: '84 BMW 318i, needs attention. Stickin' with it
1:25 450+ hp DSM build, Click here for thread
Old 11-24-2005, 01:39 AM
Lambo003's Avatar
Lambo003 Lambo003 is offline
Re: Re: Re: CSC on clear & chrome part?
Yeah, I'd play it safe and NOT use any type of stripper on the windows. Best probably to use a rubbing compound and work the paint off clear parts. However, I have stripped Tamiya paint from clear parts before using rubbing alcohol with pretty good results. The parts were usually left cloudy afterwards but, a good plastic polish like Novus will bring it back to new. . .
As far as getting paint off chrome though, I think you're pretty well screwed there. Any attempt to remove paint from this surface will only ruin it.
Chuck
Old 11-24-2005, 02:51 AM
gionc's Avatar
gionc gionc is offline
Authorized Vendor
I succesfully clean my '250 california windshield (mistake: drop of liquid cement, clear melted, went white insthead clear) simply polishing it: I start with abt. 4000 grit, then 8000, after that I glossy-up scratches with compounds: before all a coarse compoud (essebiemme) and then 3 step Tamy compound
before
after
not perfect but better I think
gio
Old 11-24-2005, 07:20 AM
ZoomZoomMX-5's Avatar
I don't use CSC; but I have heard that it tends to be safe to use on kit glass (don't use it on diecast or resin); I'd try to carefully sand/polish the paint off unless it's really thick. The same method to wetsand/polish paint works to repair kit glass, if you're careful.
If it's acrylic paint you can remove it with Windex or rubbing alcohol.
As for chrome; whatever will strip that paint will strip the chrome. Unless the paint is acrylic where you might get away w/using rubbing alcohol or Windex. No guarantees though, but worth a try.
My Fotki Album
