Go Back   Automotive Forums Car Chat > Dodge > SRT4
Old 11-23-2005, 10:23 PM
2141pete 2141pete is offline
air intakes
I just got my srt-4 and dont know much about it. Do I really need to buy a cold air intake or could I just take the lid off my stock air box it seems like it would pretty much be the same thing?
Old 11-23-2005, 11:19 PM
TEXSRT4 TEXSRT4 is offline
Re: air intakes
the cold air intake will give you better throttle response and a bit more power
Old 11-24-2005, 09:13 AM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: Re: air intakes
Would that depend on the location and the lenght of the tube?
Old 11-24-2005, 10:10 AM
air intakes
I've already took the lid off and looked it looks pretty much the same as a cold air intake would but I get a real bad flutter when I back off the throttle I put it back on and its fine. I heard the flutter might be from loose intercooler hoses but I havent got a chance to check them yet
Old 11-24-2005, 12:23 PM
Re: air intakes
flutter is normal, its the factory surgevalve opporating. it makes more power because of the smooth transition. filter location also helps. look at it this way. factory piping is small, tight bends, and coregated piping. aftermarket is larger, smoother.
the same reason intakes give power on most cars
oh, and i promise you have a loose intercooler hose, infact, odds are...they are all loose
Old 11-24-2005, 01:42 PM
air intakes
thanks for the help I'll try and get them checked out and tightened today.Anything else I should check while I'm under the hood?
Old 11-24-2005, 03:02 PM
air intakes
is it going to hurt the car at all to run around with the airbox lid off or is it not really going to help at all. I tightened the intercooler hoses up and that helped with the flutter alot
Old 11-24-2005, 06:37 PM
Re: air intakes
no, not going to hurt anythign at all
