Go Back   Automotive Forums Car Chat > Toyota > ES300/ES330/Windom
Old 11-23-2005, 07:42 PM
bbelyeu bbelyeu is offline
Unhappy Fuel Problem
1992 Lexus replaced engine (80,000 miles) everything was fine but all of a sudden it started poaring white smoke out the exhaust and using alot of fuel. Went 40 miles and car used $10.00 of gas. When sitting idle, white smoke is coming from exhaust with a raw fuel smell. Replaced one fuel injector, spark plug has to much fuel on it. What would cause this to happen? Engine is running smoothly but dumping fuel.
Old 11-24-2005, 10:00 AM
Toysrme's Avatar
Toysrme Toysrme is offline
AF - Advisor
Send a message via ICQ to Toysrme Send a message via AIM to Toysrme Send a message via Yahoo to Toysrme
Cool
You severly blew a head gasket & the car went in limp mode.
Have a compression, or cylinder leak-down test done on each cylinder.
Be sure to write down the results of each cylinder.
Toysrme257th - AIM about anything, anytime; including v6 turbos.
World's second ES 300/3vz-fe Turbo.
