Old 05-31-2002, 01:50 PM
Frostbyte Frostbyte is offline
Send a message via ICQ to Frostbyte
HELP! Car issue!
Ok my car right now is broken down. I have a question. The car goes into all the gears and the engine revs. The cam spins and the alt belt is on but the car will not move. I think it is something with the clutch or flywheel or axle. Tell me what you think that it might be. When I try to go forward I hear a rubbing noise but the car will not move. What possiblites could it be?
1989 s13 Fastback
Tein HE coil-overs
sr20det swapped!
JIC Magic Front and Rear Strut Bars
Slotted and Cross-drilled Rotors
S/S Brake Lines
Pivot Lazy eye controller
Blitz LM Intake
Blitz D1 Spec Turbo Timer
Soon to come:
Sard 550cc Injectors
Blitz Nur Spec Exhaust
Blitz Down pipe
HKS FMIC
http://www.driftmonkey.com (Part Owner)
Old 05-31-2002, 02:24 PM
ivymike1031 ivymike1031 is offline
Send a message via AIM to ivymike1031 Send a message via Yahoo to ivymike1031
Don't focus too much attention on the cam or alternator - if the engine runs, then the cam is definitely turning. The alternator is just there to keep the battery charged...
The flywheel is basically just a big lump of metal that keeps the crankshaft spinning at a constant rate - not much chance that it's the culprit. If the flywheel was completely disconnected from the crankshaft, your engine speed would fluctuate wildly (if the engine ran at all). The clutch pressure plate bolts to the flywheel, and one side of the clutch disk rubs against the flywheel, but that's about all the flywheel is involved with.
If the engine is running and the car won't move in any gear, chances are good that the clutch isn't engaging. Usually a slipping clutch makes quite a racket, and stinks really bad. Have you recently done anything to the clutch?
If one of your axles was broken in two, that would also prevent the car from driving, but I suspect that you'd hear more than a little rubbing noise.
If all the splines were chewed off of the hub, so that the axle no longer engaged with the hub, that would keep the car from driving... don't know how that would ever happen on a civic though.
What have you done to this poor car lately?
Come on fhqwhgads. I see you jockin' me. Tryin' to play like... you know me...
Old 05-31-2002, 03:05 PM
Nothing much but I do sometimes take off real fast. I don't smell clutch but I do hear like a rubbing noise comming from the tranny. Of course I didn't rev it up to much I did take it past 3 grand. When I do rev the motor up the rubbing get louder. Now I can leave the car in first and let the clutch out but the axles don't move only the rubbing noise comming from the tranny. Now it does some like a soft disc sliding acrossed a metal surface. I wonder if there is some piece on the clutch that is causing it to not grab?
1989 s13 Fastback
Tein HE coil-overs
sr20det swapped!
S/S Brake Lines
Blitz LM Intake
Soon to come:
Blitz Down pipe
HKS FMIC
Old 05-31-2002, 03:15 PM
is it cable-actuated or hydraulically actuated? Does the pedal feel normal?
Old 05-31-2002, 03:28 PM
It is Hydro and the Pedel Feels good. It is soft like it has always been. I am running the Stock clutch and I have been racing it for a year and I do speed shift everytime I race. I have 100,000 miles on the car. When I think about it there is really nothing else it could be but the clutch. I feel the stick go to all it's gears infact my reverse gear makes a small grind noise everytime I put it in and it did that so I know that the gears are going in and they are spining just the skidding noise comming from the tranny. I can't think of it being anything else other then the clutch.
1989 s13 Fastback
Tein HE coil-overs
sr20det swapped!
S/S Brake Lines
Blitz LM Intake
Soon to come:
Blitz Down pipe
HKS FMIC
Old 05-31-2002, 06:36 PM
white97ex's Avatar
white97ex white97ex is offline
Send a message via AIM to white97ex Send a message via Yahoo to white97ex
well, this is a fickle dillema. it sounds like the clutch...but if it goes into reverse and makes a grinding noise, that would mean the gears were spinning. and it would do the same in all the other gears.... my suggestion would be to call a shop and see if they could offer some insight...just my .02 though
My name is Russell, feel free to use it.
I'd rather be hated for Who I Am than be loved for Who I Am Not
Old 06-01-2002, 12:06 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
it could also be the part of the engine the clutch attaches to, the name skips me now, but you know what i mean.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 06-01-2002, 12:30 AM
ric's Avatar
ric ric is offline
Send a message via AIM to ric
im gonna go with the differential. i love these guessing games.
Old 06-01-2002, 07:19 AM
Mugen_R's Avatar
Mugen_R Mugen_R is offline
Send a message via AIM to Mugen_R
Sounds either like the differential is messed up, but then you'd hear weird noises in your tranny, or it is the clutch.
Old 06-01-2002, 09:04 AM
RickDaTuner's Avatar
RickDaTuner RickDaTuner is offline
if you ask me, and thats only if you ask me, id say your clucth blew up inside the bell housing, one to many hard lauches on a clutch with lots of friction material causes the little begger to literaly explode i wouldnt be surpised if you pulled off your trany and the was like clutch jiblets every were, diferentil ona civic are kinda bomb proof, if you run a mildy tuned engine, you can never create enough stress on it to break it, true you car is a little high on the Miles but these things last a long ass time
"Dude you must be a Shinto Munk, cuz i aint never seen so much love for rice on a car!"
AF'S
BROWN BOY CREW,
CARAMELO CREW
Old 06-01-2002, 10:50 AM
It could still be the clutch - it doesn't have to transmit much torque to give you that little grinding sound when trying to find R. Now if it makes that noise all the time when in R, that's another story...
Old 06-01-2002, 12:03 PM
Yeah! I found out what it was. It was the cup on the outer part of my Driver Side Axle. The Axle just spins but doesn't spin the wheel. That is ok I have a life time warrenty on my axles. =)
1989 s13 Fastback
Tein HE coil-overs
sr20det swapped!
S/S Brake Lines
Blitz LM Intake
Soon to come:
Blitz Down pipe
HKS FMIC
Old 06-01-2002, 12:43 PM
so the cv joint completely failed, but the boot is still intact? That falls in the category of "axle busted in two" I guess. I'm surprised that you didn't hear more noise (like the axle shaft flopping around freely in the wheel well).
Glad you figured out what it was w/o too much hassle.
Old 06-01-2002, 02:30 PM
Thanks for your help Mike I am going to be fixing it today.
1989 s13 Fastback
Tein HE coil-overs
sr20det swapped!
S/S Brake Lines
Blitz LM Intake
Soon to come:
Blitz Down pipe
HKS FMIC
