Go Back   Automotive Forums Car Chat > Chrysler > Cirrus
Old 11-23-2005, 07:53 PM
CMizzle CMizzle is offline
Oil Check light flickers on/off when i brake/in idle
its been going on for about maybe 1 week didnt have checked
its a Chrysler 1998 Cirrus LXi
when i stopped in the jack in the box drive thru in Gardena, CA and put in park...the red Oil light on dash flickered on/off...days later when i was about to hit the 405 S Freeway, as soon as i braked at the red light it came on flickering, then it always goes away when i am off park/brake
THANKX!
Old 11-29-2005, 03:01 AM
jabby_jabby's Avatar
jabby_jabby jabby_jabby is offline
Re: Oil Check light flickers on/off when i brake/in idle
this seems to be a common problem amongst cirrus's. own own cirrus did this. i still havent heard a definite answer as to why it happens.
Old 12-09-2005, 07:08 PM
Roleh Roleh is offline
I just brought my car in on Tuesday for this very same problem. My mechanic diagnosed my problem as being the "Oil pressure sending unit" and also referred to this part as a switch and stated that it had been leaking oil. The part was only $17.25 and my car was in and out in a matter of 2 hours.
He explained that there was in fact nothing wrong with my oil pressure, it was just the sending unit sending a faulty signal. I wouldn't take a chance on it though. Of course, today it began blinking again while I idled at a stop light. I'm not quite as freaked out, realizing what the problem most likely is, and will have it back in on Monday morning.
Old 12-28-2005, 04:13 PM
what happ when u brought it back on monday?????
its still doin it
Old 02-14-2006, 09:39 AM
kplusten kplusten is offline
I went thru the same drill, replaced oil pressure sensor. The oil pressure light would go out if I placed the tx in neutral when stopped because the idle would increase slightly. The low oil pressure reading was coming on due to sub-idle rpm. I increased the idle slightly using the set screw on the throttle body, cleaned the throttle body, and the problem is gone.
Old 09-07-2006, 11:39 PM
geigerk geigerk is offline
Thumbs up Re: Oil Check light flickers on/off when i brake/in idle
THANKX!
i had the same problem when i bought my 95 !!! it is preety tipical!! as long as you got oil then odds are it is the sending unit! there not very exspensive i beleive i paid approx. 18 dollars and about 20 min. installing! all you have to do is remove oil filter it is rite beside it and it gives you a good reason to change your oil at the same time all in all it costs about 35. dollars forgot to mention this is on the 2.5 v6 but shouldnt be to much diff. if its the 2.4 4cyl
