Go Back   Automotive Forums Car Chat > Cadillac > Seville
Old 11-23-2005, 03:57 PM
bollo man bollo man is offline
Question 93 seville code problem
I recently used a code key on my cadi and it read " set timing mode ". can anybody tell me what that means. thank you
Old 11-24-2005, 07:04 AM
DFBonnett DFBonnett is offline
Did the code key have two projections on it on one side? You put it into the port under the dash on the driver's side? I think it may be a tool to jump the A & B connections in the diagnostic port. Most just use a bent paper clip. This is used to put the car in timing mode so you can set the base ignition timing with a timing light. Once the key is removed you are out of that mode and the comp goes back to controlling the timing as usual. No harm done.
Old 11-24-2005, 10:33 AM
maxwedge maxwedge is offline
A990 racer
Re: 93 seville code problem
This has obd thru the ac control panel, go to caddyinfo.com for the instructions.
Old 11-24-2005, 10:38 AM
butch h butch h is offline
If you need to access codes,you can enter the diagnostic mode by holding the climate control off &warm buttons together.
