Go Back   Automotive Forums Car Chat > Mazda > Millenia/Xedos 9
Old 11-23-2005, 01:21 PM
JenniferR722 JenniferR722 is offline
Millenia Dying...
I have a 95 Millienia, and all it does is die. When I'm on the highway, when I'm at a stop light, when I'm turning, or just driving on a regular city street. No one can seem to figure out what's wrong with it...
i've had the distributor replaced, the in-take accleration hose replaced,
put water remover in my gas tank (didn't have a gas cap for a while) and it's still dying. I did have a diagnostic ran on it, the EGR came up, Knock Sensor, Distributor (fixed) and Speed/Signal failure....any ideas what it could be?
Old 11-23-2005, 02:19 PM
mazdatech177 mazdatech177 is offline
Re: Millenia Dying...
did you replace the distributor with an assembly from the dealer? you dont want to use a junkyard or aftermarket part here. if you did though, i would look at the crank position sensor wiring on the area by the drive belts. also ive seen some MAP/BOOST sensor problems causing a stalling concern. its kinda hard to tell from here hope that gives you some places to look
Old 11-23-2005, 02:35 PM
Re: Re: Millenia Dying...
NO no....I got the distributor from Mazda and had my grampa put it on (he races cars...actually races a Mazda Miata...lol and he's 70!!)
I'll have my mechanic take a look at the things you mentioned tho!
Thanks for the help!!! ;o)
