Go Back   Automotive Forums Car Chat > Chrysler > Concorde
Old 11-23-2005, 10:05 AM
jeeps4life jeeps4life is offline
Angry 99 concorde interior lights won't go off
All of my interior lights(map, doors, rear courtesy lights) stay on constantly unless I pull the fuse. Of course then I lose all my radio presets and it urkes me . I saw that some other people had the same problem but the posts were from last year. Has anybody found/fixed the problem? Please help I love my Concorde
Old 11-27-2005, 10:45 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: 99 concorde interior lights won't go off
your power wire is shorted to power. I've seen before on some other Chryslers that along the inside portion of the "A" pillar, you have wires that run along there that control the lights, they have a tendency to get pinched & cross wire themselves to another circuit thus shorting to power, you might want to check that out. Also, have the BCM checked out, it may not be going to sleep thus allowing those lights to turn off.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 11-29-2005, 11:19 AM
Re: Re: 99 concorde interior lights won't go off
Thanx I'll check it out.....yesterday, for the first time, the lights started to dim out then just before they went completely out BOOM they came back on.
Old 01-24-2007, 02:04 PM
Laffy71 Laffy71 is offline
I have a simmilar problem with my 93 Chrysler Concorde! I just bought it from a private dealer last week, run's awesome, handles great, only 90 Thousand Miles. Problem is there's a short, or at least I am thinking it's a short, in the front passenger door! Everytime I hit a bump the Red Door is open light comes on, and the interior lights come on! I figured out it must be the passenger door cause when I give the door panneling a little tug, the lights go out!
I would love to just pull the fuse, however according the manual this fuse is also responsible for the Power Windows and Door Locks! Anybody got any idea's on what I should do? It's driving me nuts! Is there a wire I could just cut?
Laffy71
Old 02-12-2007, 07:41 PM
ConcordeGuy ConcordeGuy is offline
This is probably not a wiring problem. More likely the plunger that pushes in when the door is shut needs adjusting/replacing. You might also want to check the door hinges as they could be worn causing the door not to close in perfect alignment thus causing the failure to close the plunger.
Old 03-05-2007, 08:11 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
that can be the problem foir both of you, check all the door plunger things to make sure they are working, then change any faulty ones, my 97 was doing the opposite, the door would open then no lights, so i just fiddled with plunger and all is good in chrysler-land again.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 03-26-2007, 09:59 PM
diggyman diggyman is offline
Wow guys I just found this fourm and first of all i'd like to say hello, great forum and knowledgeable folks.I just bought my 1996 concorde about 3 days ago also...yep you guessed it.The interior lights wanta stay on.its fine as long as the car is on but soon as i turn the car off the interior lights come on and stay on.I just disconnected the battery and i gotta put it back on in the morning to go to work.I will most definatly check the door plungers.THANKS!
Old 08-22-2009, 12:04 AM
jamesch jamesch is offline
dont know if you fixed it but my gear shifter wont go forward all the way and that keeps mine on until the battery dies so if you have not fixed it yet you might want to try that
Old 10-16-2009, 04:17 PM
KyleW KyleW is offline
I went to Chrysler dealership where I was told you needed to try WD 40 spray. Try to spray all of your door ajars an latches. Every 2nd day 3 times (so 1 week).
Also change your battery and/or battery cables.
Hope these help!
