Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 11-23-2005, 10:02 AM
Privatebigandrew's Avatar
Privatebigandrew Privatebigandrew is offline
Send a message via AIM to Privatebigandrew Send a message via Yahoo to Privatebigandrew
Speedometer and Final Drive
I have a quick question that i am unsure of the answer to. I just recieved a civic type-r transmission with an integra 98'+ spec type-r final drive. (4.785 instead of 4.400). I opened the trans up to verify also. My question is this. Since the speedometer reads off the final drive, will it be off? Or does it even run off the final drive; i'm pretty sure it does. Any help is appreciated.
94' Del Sol VTEC (B16A3) SOLD.
Accel plug wires, NGK iridium IX plugs, AEM short ram intake, DC sports ceramic coated header (4-2-1), Airmass high flow cat ,Custom Magnaflow exhaust, Bosal Brospeed tips, Neuspeed short throw shifter, Tokico clutch master cylinder, Tokico clutch slave cylinder, Prothane complete kit bushings, Brembo front rotors, NR EL-Glo instrument gauges, CTR LSD trans with ITR final drive, Exedy chromoly flywheel, ACT HDSS clutch kit, Raxle axles.
Old 11-23-2005, 11:15 AM
Kven's Avatar
Kven Kven is offline
Re: Speedometer and Final Drive
Nope, it wont be different from a 4.4... You're right that the speedometer reads off the final drive; the Type-R final drive turns just as fast(assuming the same size wheels/tires) as a 4.4:1 Final drive at, say 50mph...Only difference is the Type-R final drive will be at a higher rpm.
HondaSwap | K20A.org | EF Honda
1988 Honda CRX DX
WTB: CRX mudflaps(both front and rear)...PM me if you have some for sale!!!
Old 11-26-2005, 08:09 AM
You were exactly right. I installed the transmission yesterday and the speedo is dead on. Thanks
