Old 11-23-2005, 10:00 AM
crazee_868 crazee_868 is offline
Front Washer Fluid doesn't work
I can not get my windsheild clean while driving, I have to stop on the side of the road and pour washer fluid over my windsheild then put my wipers on to clean it. I can not get the spray mechanism to work. Any suggestions? I have got the lines blown clean, used a test light to check the power and tested the fuses.....out of ideas....please help...live in a crazy weather area....need fluid to front of truck as driving backwards is not an option. Thank you in advance
Old 11-23-2005, 10:03 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: Front Washer Fluid doesn't work
Well if you're getting power to the connector, Replace the motor...about 10 bux...(remember, you have 2 of them)
Old 11-23-2005, 10:15 AM
Thank you I will get that checked
Old 11-23-2005, 10:18 AM
Gabe25's Avatar
Gabe25 Gabe25 is offline
Re: Re: Front Washer Fluid doesn't work
If your motor is running, then check at the end nozzle. Disconnect it and see if water comes out. If not, replace the motor. If so, you got pluged nozzles. Replace them or using a thin wire you can try to unplug them.
1994 1st.Gen. S10 Blazer Tahoe
Aloha
Gabe
My Fleet
Old 11-30-2005, 08:47 AM
Re: Re: Re: Front Washer Fluid doesn't work
Is it possible that my windsheild washer module needs to be replaced? Does this part affect the fluid disbursment?
Old 11-30-2005, 08:58 AM
rlith's Avatar
Re: Re: Re: Re: Front Washer Fluid doesn't work
The module? Are you talking about the piece attached to the fluid resivoiur or the multifunction switch on the steering column?
Old 11-30-2005, 09:08 AM
Re: Re: Re: Re: Re: Front Washer Fluid doesn't work
Well that's a good question, I have the problem with my wipers working sometimes and not shutting off othertimes and the mechanic said that the module piece will fix both problems. Does that sound right?
Old 11-30-2005, 03:15 PM
Gabe25's Avatar
Re: Re: Re: Re: Re: Re: Front Washer Fluid doesn't work
That sounds like it. Providing that he checked the motor for your washers. Good luck........
Aloha
Gabe
My Fleet
Old 01-20-2006, 10:48 PM
joeuser742 joeuser742 is offline
If you haven't found/fixed the wiper problem yet...I had the same problem when it got cold out. It was a clogged/frozen line up by the hood. I use that antifreeze fluid now and haven't had the problem since.
Old 01-21-2006, 07:37 PM
manwiththeplan88's Avatar
manwiththeplan88 manwiththeplan88 is offline
If you manage to fix it let us know how you did it because I have the same problem, by the way, which fuse it?
