Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 11-23-2005, 09:48 AM
CharQuake CharQuake is offline
replacing the door speaker
how do i pull the door panel on my 03 seirra to replace a blown door speaker... a detailed description of where all the retaining clips are would be much appreciated
Old 11-24-2005, 07:26 AM
86in 86in is offline
If it is the same as my 99, its easy. pry off the cover that holds the power window and lock switches, and the upper corner triangle, and the actual sliding lock. They come off rather easy. There are only 2 or 3 screws, I forget where, but they are easy to see. Then the whole panel slides up and off. If you take out your pocket storage at the bottom of the door and look in , you will see how it is in there. There arent any of the cheap plastic rivets like some cars have. Check out in this forum a title called Sierra talk, it has a link to a forum for just Sierra owners. I joined, its really nice. Good luck!
