Old 11-23-2005, 08:51 AM
91transamny 91transamny is offline
Help on removing Emissions
Alright i need some help i have a 91 trans am Gta with a 350 tpi and i want to revove the emissions. I already guted the cat but i want to remove all the smog crap and shit like that but i have never done it before on a car and i need some help on what to do
Mods List
-350 4 bolt main swap
-Tremic tko 600 5spd
-slp dual cold air intake
-flowmaster
-l98 heads
-chip
b&m short throw
24lb injectors
373 posi rear
msd ignition
Old 11-26-2005, 09:16 AM
Philo Philo is offline
Re: Help on removing Emissions
Mods List
-flowmaster
-l98 heads
-chip
b&m short throw
24lb injectors
373 posi rear
msd ignition
You can't legally remove the smog gear and use the car on the road. Once you have been discovered, you will never be able to pass inspection until it is put back to original. NY is getting more and more strict on smogged cars, because of Federal pressure. The best thing is to make everything work 'as new' that is on the car. It was made to run as well as possible with the smog gear. If you want a non-smog car, you should get an older car.
Old 11-29-2005, 02:19 AM
ikeyballz ikeyballz is offline
Send a message via AIM to ikeyballz
hm. im not sure if it was here..but try check thirdgen.org someone had a how to: on how to gut out the smog reg. air pump...try check it out
