Old 11-23-2005, 08:02 AM
getajeep getajeep is offline
Omg!!
Ok i checked all the wiring, Its all in tact, i dont know what else to do, i havent been able to get a new switch yet but its seventy bucks are you guys sure it is the switch, why would it turn on the front lights and not the back ones sounds kind of weird to me...
Old 11-23-2005, 10:22 AM
Saudade's Avatar
Saudade Saudade is offline
Re: Omg!!
OK, first of all, please DO NOT start a new thread. It splinters everyone responses. You've started, at least 4 different threads on this topic. I had no clue over what switch and lights you were referring to until I hunted down your other posts.
Next, try using a subject that describes your problem. Not OMG!! or HELP! No problem adding them to the subject but you need more than that. That allows people to understand what you're looking for so they can decide if they can help or not from the subject line and not have to read the posts.
When you say you checked the wiring, was that a visual check? Did you use a multimeter to trace them? Do you have power where it should be and ground where it should be? Did you ever get your wiring diagram?
Tracing wiring is not difficult. What's difficult is knowing which wires to trace and how the specific circuit works. I have a Chilton repair guide and the FSM. I've found the Chilton is OK for my year, despite some of the wire colors being inaccurate. It tells me how the switches are configured, where each component draws power and how the circuit grounds.
Old 11-27-2005, 10:01 AM
vamc's Avatar
vamc vamc is offline
Re: Omg!!
Relax!
