Old 05-31-2002, 10:27 AM
jjguitar jjguitar is offline
Send a message via AIM to jjguitar
funny smell when pedal is put to the floor?
I own a 1987 Grand Marquis. The car runs great and is in great shape. If I accelerate at a fast pace....or even floor it....I smell something burning...like oil burning...after I do so. Should I be concerned? Is it just because the engine has 130K on it and is not running as effeciently as it once did, so when I step on it, it burns a little oil?
Old 06-01-2002, 12:23 AM
Gonthrax's Avatar
Gonthrax Gonthrax is offline
Skyline Guy
Send a message via AIM to Gonthrax
Is it a manual or automatic? If manual, have you noticed any acceleration problems? Perhaps slipping clutch resulting in that hot clutch smell?
Member of AF's Slide Squad (Member #04)
Originally posted by taranaki
Postcounts - Phoey....it's not how often you speak,it's whether you actually say anything that matters.
Neishlin Motors
Soon to be my best friend
Old 06-01-2002, 08:05 AM
It is an automatic, and acceleration seems to be smooth.
Old 06-01-2002, 11:21 AM
ivymike1031 ivymike1031 is offline
Send a message via AIM to ivymike1031 Send a message via Yahoo to ivymike1031
It wouldn't surprise me any to find that you have a leaky valve cover gasket (or other oil-retaining gasket), and that when you accelerate rapidly, oil is finding its way onto the exhaust manifold &/or pipes.
Increased blow-by during high load operation could also make an oil leak worse, especially if your crankcase ventilation system wasn't working properly.
Check for engine oil leaks, and make sure that your PCV valve(s)/tubes aren't clogged.
Come on fhqwhgads. I see you jockin' me. Tryin' to play like... you know me...
Old 06-01-2002, 12:12 PM
Thanks....I know for a fact that I have an oil leak through the oil seal, I'll check for the other things.
