Go Back   Automotive Forums Car Chat > Honda > JDM Motor & Parts info/chat
JDM Motor & Parts info/chat Discussions on Mugen, Spoon etc. Plus, info on motor swaps (b18 's, b16's h22's etc) and other JDM info!
Old 11-23-2005, 12:21 AM
GoRi GoRi is offline
Question best of d seires?
Ok i kno not alot of people dont like the d-series engine but its what im goin to start with. I wanted to know which d-series engine would be good for NA. I remember reading a post saying that it can push 200hp. Is this really possible? Im starting to save up money for mods an i have around $2500 right away. This will be my first project car so i wanted to start with something small.
Thanks for the help!
Old 11-23-2005, 12:31 AM
Re: best of d seires?
I forgot to mention i drive a 94 civic coupe. Also what would be a good tranny for it?
Old 11-23-2005, 01:32 AM
Przemir4g Przemir4g is offline
the best will be D15B from Japan - stock 130hp my friend with new cams has more than I have from B16A1 and he is fastest than me /my best et for 1/4 14,5/ if u need more info let me know
Old 11-23-2005, 06:24 AM
o0o0o but can it push 200hp? if yes what would you need to do to it?
Old 11-23-2005, 06:25 AM
And where will i be able to get one of those engine because i dont see them anywhere online?
Old 11-23-2005, 06:30 AM
Plus is there a better tranny for it from another d-series or not?
Old 11-23-2005, 06:31 AM
Sorry for so many questions.
Old 11-23-2005, 09:40 AM
200HP? ITB, cams, fuel managment, spark man.., hondata 300 or something to talk with ECU and no problem
in poland one company sells stuff from japan - trie on google in japan
"better tranny" what U meen ?
Old 11-23-2005, 11:10 AM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
why not boost....more power than that and less cost....
www.turbod16.com
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 11-23-2005, 11:28 AM
alphalanos alphalanos is offline
The stock d16 is good for around 180hp or so. (thats all i would put into it anyway) however built I have seen as high as 400-450. I highly recommend you consider going turbo.
96 EJ6. Future home of boosted B18C1.
Old 11-23-2005, 12:35 PM
I heard closer gear ratios are better for NA engines or something like that so which one out of all the d-series transmissions is good? I know turbo will give me alot of power but you dont see many all motor d-series around here so itll be something interesting to do you know.
Old 11-23-2005, 12:53 PM
Schister66's Avatar
AF -Advisor
you don't see many all motor d's because they cost a lot and don't make a lot of power....if power's what you're looking for, then boost is your friend!
Old 11-23-2005, 01:01 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
There's a reason why you don't see too many all motor d-series. It's just not worth it when you could put OE Honda parts (ITR and CTR) into a b18c1 and easily make more power, without having to resleeve or pay for expensive aftermarket cams etc. But it's your car and your $, so you should od what you want and not what others say.
There isn't 1 out of the D-series that is best. I guess you could say the d15b vtec LSD tranny is best, only because there was an option for a factory LSD. Other than that, the '92-'95 Si, '92+ EX's (Coupes specifically), and the d15b vtec have pretty much the same gearing (I'm pretty sure they are exactly the same).
Old 11-23-2005, 01:07 PM
Thanks for the info guys
Old 11-23-2005, 01:45 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
to get higher hp from a sohc d. you need to have that motor sleeved and bored 12:1 cr. the biggest cam you can run with those high comp pistons. one of those $800 dollar equal length header. itbs would be the best for power, p&p head. and of course the most important part, a really good tune. how high you cr can go is related to how high of an octane gas you have available
Team Lonely Drivers
