Go Back   Automotive Forums Car Chat > Honda > Del Sol
Old 11-22-2005, 11:33 PM
Privatebigandrew's Avatar
Privatebigandrew Privatebigandrew is offline
Send a message via AIM to Privatebigandrew Send a message via Yahoo to Privatebigandrew
New Parts
Well, i sold my 97' hatch and with the money i decided to do some upgrading to the ole sol. While my ex had the car, the clutch amaziling got all screwed up. Seriously, it was going bad anyhow. I think the pressue plate is all screwed up or either the throwout bearing. When i push in the clutch at high rpm's it acts like i didnt even push it in...does absolutley nothing. I already checked the master and slave clyinder and they are working fine. But it doesn't matter anyhow, because i just recieved my new driveline parts. I decided to go with an exedy chromoly flywheel (9 lbs) and an act HDSS clutch and pressure plate. To top it all off, I ordered a civic type R trans with an integra type R final drive. (4.785 vs 4.400) So the acceleration will be a lot better, but gas mileage will of course suffer a tad. But you have to give something up. I am really looking foward to the LSD in the corners. I guess we will see what it can do. Hopefully if all goes well, she will be up and running again this saturday. I will keep you guys posted.
94' Del Sol VTEC (B16A3) SOLD.
Accel plug wires, NGK iridium IX plugs, AEM short ram intake, DC sports ceramic coated header (4-2-1), Airmass high flow cat ,Custom Magnaflow exhaust, Bosal Brospeed tips, Neuspeed short throw shifter, Tokico clutch master cylinder, Tokico clutch slave cylinder, Prothane complete kit bushings, Brembo front rotors, NR EL-Glo instrument gauges, CTR LSD trans with ITR final drive, Exedy chromoly flywheel, ACT HDSS clutch kit, Raxle axles.
Old 11-26-2005, 09:16 AM
Re: New Parts
Well, we were so slow at work on friday that i decided to install the whole deal then. Installation was a brezze. The only problem i had was the rear mount didn't want to line up right with the new transmission. But a little persuasion fixed that problem perfectly. The clutch is awesome. I would highly recommend it to anyone. It grabs when you want it to, or it can be as smooth as a stock clutch if you go easy on it. The flywheel...well i can't really comment on that one yet, as i haven't been able to get on her due to the break in period o the new clutch. But as i can tell, it seems more responsive. It is a little touchy and takes only minimal skill to get used to. Overall i am very happy with the setup. The transmission made the car feel like a new animal. Around the corners the thing just pulls like it never could before. Acceleration is a lot smoother and faster. By far, this is the best performance mod i have ever done to my car thus far. That might change though when my suspension comes around.
