Old 11-22-2005, 09:33 PM
Cbierniat's Avatar
Cbierniat Cbierniat is offline
Foglight bulbs
Is there an upgrade or anyway i can make my fog lights brighter or even a blueish purple tint?
tahnks
Old 11-23-2005, 01:03 AM
kustomkid54's Avatar
kustomkid54 kustomkid54 is offline
Re: Foglight bulbs
This may help,
http://www.automotiveforums.com/vbul...ght=Fog+lights
tahnks
Old 11-23-2005, 10:50 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Foglight bulbs
If you're cheap like me you can put in direct fit #893 lamps which are 37.5 watts. No mods are needed to the holder, wiring, fuses, or relays. I've had them for over 4 years and no burnt wiring or electrical sockets.
Going to 50 - 55 watt lamps requires bracket/holder mods and the fog lamp relay and fuse should be upgraded to 15 amps due to the extra current draw. It's better to install a separate 15 amp relay kit. Just my 2 cents.
Timeslip 08/12/06
AF Community Guidelines
Old 11-23-2005, 01:19 PM
Cbierniat's Avatar
Re: Foglight bulbs
THanks guys
Old 11-28-2005, 07:21 AM
wilbart49 wilbart49 is offline
I was under the impression that the #893 / 37.5 watt bulbs will burn out my wiring. Is this not the case?
Old 11-28-2005, 07:55 AM
BNaylor's Avatar
Re: Foglight bulbs
I don't have any problems using them but it may vary depending on how you use the fog lights. If you use them as running lights then I would be cautious about using #893 / 37.5 watt or any higher wattage lamps without any modifications. Hopefully, the 10 amp fuse pops first.
Timeslip 08/12/06
