Old 11-22-2005, 08:19 PM
Bravada 97's Avatar
Bravada 97 Bravada 97 is offline
Light Bulb For Headlights.
I am thinking about getting new headlights for my 97 Bravada. I was wondering if these will work or if anyone had tried them in their vehicle before.
The light bulb: Blue 9006
http://cgi.ebay.com/ebaymotors/ws/eB...MEWA%3AIT&rd=1
The 4x6 Diamond Back Headlight conversion:
http://www.slickcar.com/productdetai...ProductID=1031
Also I see that the bulbs are listed as "8500K H.I.D." What exactly does the number mean? I guesssed that the higher the number the brighter the light?
Thanks for any info.
Old 11-22-2005, 08:34 PM
SComp23 SComp23 is offline
Re: Light Bulb For Headlights.
No, do not get those. 8,500K is a color rating, and actually the brightest light available in automotive lighting is HID, which is 4,300K. And do NOT get the APC conversion, I got them for my Dad once and took them back the next day, the output is horrible! If you just want a simple halogen conversion, get some E-Code conversion 4x6 headlights from a seller named riimc I believe off of ebay, and some high-output philips bulbs, or even some silverstars, or get an upgraded headlight harness and some high-powered bulbs.
Old 11-22-2005, 08:51 PM
Bravada 97's Avatar
Re: Re: Light Bulb For Headlights.
Thanks for the help SC. I didn't know that diamond back headlights had poor output. Being that they are common on most new vewhicles I figured it would be a better choice than my factory lights.
I will look into the headlights and bulbs you listed. Are the Phillips bulbs white/blue in color like HID lights?
Old 11-22-2005, 09:24 PM
No the philips ones are just extended life ones with a bit higher output. Try you find some HIR bulbs on ebay or some Osram Silverstars. The Sylvania ones are sweet, but the Osram ones are a bit better and sole only over in Europe, so check on ebay for them. Also check the conversion lights I spoke about from ebay, if you cant find them, IM me on SComp23.
Old 11-22-2005, 10:16 PM
Bravada 97's Avatar
Thanks SC, I found that seller on e-bay and found these two styles of headlights:
http://cgi.ebay.com/ebaymotors/200mm...QQcmdZViewItem
and:
Old 11-22-2005, 10:23 PM
Yes Sir, get the ones with the clear lens not the fluted ones, the first link you posted. I bought these for my Dad and was very pleased with the output, you will notice a huge difference in the output!
Old 11-22-2005, 10:32 PM
Bravada 97's Avatar
Right on! I am going to e-mail the seller and see if he has any available for a 97' Bravada. Thanks again for the help.
Old 11-22-2005, 11:14 PM
s10blazerman4x4's Avatar
s10blazerman4x4 s10blazerman4x4 is offline
Send a message via AIM to s10blazerman4x4
And im correct to presume that these are plug n play for the first gens like my 91?I have been waiting for a recommendation to buy some new headlights for awhile.
1991 Chevy S-10 Blazer 5.7 V8 RIP
1999 Chevy Blazer 2dr 4.3
Old 11-23-2005, 02:35 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
I have them installed in my low and my high beams (9005) and I absolutely love them.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 11-23-2005, 11:27 AM
Bravada 97's Avatar
BlazerLT, are you refering to the bulbs or the bulbs and headlight?
I contacted the e-bay seller about the lights that SC recomended but he only carries them for the 91-94 Bravada. It looks like i may be outta luck. The link ot those is below.
Old 11-23-2005, 12:12 PM
Gabe25's Avatar
Gabe25 Gabe25 is offline
Re: Re: Re: Light Bulb For Headlights.
BlazerLT is refering to the bulbs. As for your car. You have a 97 Bravada and you just need to replace the bulbs as well. Unless your looking at replacing your whole light assembly. As for me. Those diamond backs are just what I'm looking for. Thanks SComp23 for the Links.
1994 1st.Gen. S10 Blazer Tahoe
Aloha
Gabe
My Fleet
Old 11-23-2005, 12:19 PM
The 97 Bravada has composite headlights don't they? I didn't think they had the 200mm sealed beams. If that is the case search for some clear reflector composites for the Bravada. Also, those are the lights I was speaking of, I bought a pair for my Dad and a pair for my brother, the beam pattern is perfect and a huge improvement over the sealed beams, you will not be dissapointed!
http://cgi.ebay.com/ebaymotors/200m...Qcmd ZViewItem
Old 11-23-2005, 04:17 PM
Bravada 97's Avatar
My Bravada does have composite headlights. I could not find any clear reflector headlights but, I think just chaning my bulbs to a brighter white light as opposed to OEM bulbs should help a lot. I think I am going to go with the Sylvania SilverStar bulbs as they seem to be a popular choice like you said.
Would a xenon bulb be better yet? I saw some 9005 xenon in the store that were only about $13 each.
Old 11-23-2005, 06:06 PM
BlazerLT's Avatar
AF -Advisor
just install the bulbs and you will be fine.
Just as a hint, I would keep the stock high beams and only replace the low beams.
Old 11-23-2005, 06:52 PM
Any bulb with a blue coating will actually be worse than a regular halogen. If they are Xenon and are clear, then yes go with those, if not, go with the Silverstars.
