Go Back   Automotive Forums Car Chat > Volkswagen > Golf
Old 11-22-2005, 07:07 PM
And Evs And Evs is offline
Unhappy MK4 Heater has packed up
Please help! My MK4 golf's heater started making a strange whurring noise and stopped. Then it started again after 10 mins or so. It is very intermitant. I can be travelling for 5 mins and all of a sudden it will start and then 5 mins later it stops. This goes on all the time. With the way the weather is at the moment and the fact my girlfriend usually drives it, I need to get it sorted ASAP. I have stripped the switch mech. and cleaned the contacts. When I put it back together it worked and I thought I had fixed it -then it stopped! Has anyone got any ideas?
Cheers
Old 11-22-2005, 08:56 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
sounds like a bad blower motor
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
Old 11-23-2005, 10:39 AM
Re: MK4 Heater has packed up
Is this blower motor easy enough to replace?
Old 11-23-2005, 05:57 PM
VDUBMAN
Re: Re: MK4 Heater has packed up
yup, 2 8mm bolts right above the lower pannel on passenger side. Might want to remove the side dash pannel on that side (prys off) to get a better look at the connector.
