Old 11-22-2005, 06:08 PM
4nak8er 4nak8er is offline
Question stuck on defrost
I have a 97 gt with a 3800 and about 100000 miles on it. My vent is stuck at defrost. How can I fix this? It's getting cold in MI and I would like to warm up my feet. Thanks.
Old 11-22-2005, 10:09 PM
regalfriend regalfriend is offline
Re: stuck on defrost
Put the car on cruise control and put your feet on top of the dashboard...Only kidding...im not sure of the answer but am sure you will get a good reply
Old 11-28-2005, 06:56 AM
jrodz jrodz is offline
I had the same problem and it turn out to be the vaccum hose going to the MAP sensor. If your cruise control doesn't work as well, there's a pretty good chance that the vaccum hose from the MAP sensor came undone, if so, reconnect it. Hope this will solve your problem.
Old 11-28-2005, 01:04 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
hey regalfriend, how ironic that your joke would be impossible, as it's most likely a vacuum line has split and/or came off, and the same vacuum line supplies the cruise as well,
Old 11-28-2005, 01:48 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Re: stuck on defrost
That's funny, I didn't know the cruise control had a vacuum line feed.
But seriously the one to check is the one that runs from the intake manifold and routes in a round about way near the battery into the big wiring harness that eventually goes into the firewall to feed vacuum to the HVAC system controls.
I worked on a friend's '98 GT a while back and he didn't know that he smashed the accessories vaccum line after a battery swapout. The battery was sitting on top of it.
Timeslip 08/12/06
AF Community Guidelines
Old 11-28-2005, 02:35 PM
richtazz's Avatar
oops, my bad. I forgot these cars have an electronic cruise module, not the old school vacuum one. I was so busy making a joke, I didn't check my facts first.
Old 11-28-2005, 02:41 PM
Re: Re: Re: stuck on defrost
Thank you. I must have pulled of the line when I took off the engine cover. It was the small line going from the back side of the manifold around to the fusebox/battery side of the engine compartment. Now I have feet heat.
