Broken spark plug
While changing a spark plug, one broke completely off with the thread still in block. 4.3l v-6
What can be done to remove it? |
Re: Broken spark plug
Never seen or heard of that happening before.
I would try pulling the center out with a needle nose vice grips or something. Then see if you can use an easy out in the hole that you should have there Good Luck man, you need it. |
i hope not!!!! Goooooooood luck |
1995 Factory Blazer Service Manual for sale, PM if interested. |
I kinda hope that's where it broke LT, but for some reason I think that it must be worst than that.
If you can't get it out with the easy out go talk to either a body man or a top notch welder about using a plasma cutter to take it out. Or they might be able to weld a nut on the broken plug. They might not be able to do anything, but you never know without asking. If none of this works then your stuck pulling the head. If it isn't on the motor you should be able to get the plug drilled out. But if you drill it out with the head on you'll have lots of little filings in your cylinder without any way to get them out. |
If the nut portion broke off from the threads, you will need to use an easyout to remove it (kinda like a reverse thread tap)
If the easy out doesn't work then you will have to drill and retap the hole
![]() ![]() 95 s10 Blazer, EGR Mod, ZQ8 Steering box mod, 99 Center console shifter mod and more... See everything at www.pghconsulting.net/teal |
If the nut portion is gone then also you should remember to use anti-seize on the plug threads so this NEVER happens again.
I would not recommend using an easy out.. I've seen them do more harm than good a few times. My last experience with one showed that they are made with the finest of japanese hardened cheese.
Try getting yourself a super out. It's something you pound in and turn as opposed to the reverse thread.
Here is what came out with the socket
![]() Here is what was left in the head ![]() I let my mechanic get it out. Didn't want to F it up any more. Well, The money I save with the DIY tuneup went to get this out. He used some heat and an ez-out. Damn emmision tests. I did use antiseize the last time I changed them. Oh, well. |
Glad that hew got it out.
That looks like 1 rusted up thread |
Re: Re: Broken spark plug
It sure was. I don't drive the truck that much so I hadn't changed them in about 4 years. I guess I will have to change them more often. |
I think you might have coolant getting into that cylinder.
I saw this on another forum about a week ago. Just for the heck of it what brand plugs are these?? I have never seen plugs break like this before. To your knowledge, was any anti seize used on them?
I used to be indecisive, now I am not so sure. |
Good job getting it out. Damn glad this has not happened to me!!!!!!!
2002 Pontiac Gram Am K&N Air Filter Mobil1 5W-30 Extended 15K 2 JL Audio 12" Subs Sealed JL Audio Box Coustic 400 Watt Class D Mono Amp Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner Polk DB750 6.5" all around Yankees Suck!!!!!!!! |
