Go Back   Automotive Forums Car Chat > Mercury > Mystique
Old 11-22-2005, 05:48 PM
fellas5 fellas5 is offline
Shift Lock Problem
Hello peeps, I'm new to this forum, so be nice! I have a 98 Mystique. I do have the check engine light on as well. I haven't had the code checked. The car is also running fine; however, my main issue is the shift lock. When I start the car and press the brake, the shift lock is not releasing. I read the manual, and found the way they recommend to manually overcome the problem; however, I would like to fix it the right way. I called the dealer, and they told me it was the brake pedal switch, but I checked that, and it's working fine, and I also still have the brake lights working properly, which confirms that the switch is not the problem, as the dealer said. Does anyone else have experience with this issue, and if so please advise.
Old 11-25-2005, 05:09 AM
KimMG KimMG is offline
AF - Advisor
Re: Shift Lock Problem
Not being familiar with your car, I have a couple of questions. How many brake pedal switches are there? And how many wires go to the switch(es)?
Old 12-15-2005, 09:31 PM
Re: Re: Shift Lock Problem
There are two switches for the brake pedal. I don't recall how many wires are there, but I will find out.....
