Old 11-22-2005, 04:33 PM
slowCRXinPitt's Avatar
slowCRXinPitt slowCRXinPitt is offline
swap problems
ok d15b vtec is in, but running like poop. Im still obd0 so no problems with that. no codes either. its idling erratically and looping. if i give it gad it sopunds fine though, but as soon as i let off the gas it stalls. i put in new plugs and wires too. perhaps the timing is off? if so how do i adjust the timing being that im using my obd0 dizzy. or should i just try and adjust the gears? please help!
Old 11-22-2005, 06:25 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: swap problems
put a timing light on it. did you just convert to mpfi or was it already mpfi ?
Team Lonely Drivers
Old 11-22-2005, 09:18 PM
Exempt Exempt is offline
Send a message via AIM to Exempt Send a message via Yahoo to Exempt
Re: swap problems
Are you throwing a CEL?
Old 11-22-2005, 10:17 PM
Re: swap problems
car was an si, already mpfi. no cel. I have the timing light, what is the protocall for using it?
Old 11-23-2005, 04:41 AM
Re: swap problems
hook up the positive and negative to the battery and the timing wire to #1 spark plug wire and start the motor.
Team Lonely Drivers
