Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 11-22-2005, 01:10 PM
craigsc2 craigsc2 is offline
SES light
Hello all, I've been a post reader for a while, however, just joined today. My daughter has a 99 SC2 that was hesitating a little when she got to about 40mph. She took it to a shop and they said it was the coil pack. I replaced one pack and the problem contiued so I switched it with the other pack. No change. Next I changed the spark plugs, air filter, EGR valve, ETC, cleaned throttle body. Now the car hesitates at about 30mph. Autozone ran the code and turned out to be the O2 sensor. Bought and replaced front sensor, assumable reset pcm by disconecting battery and pulling fuses. Car still hesitates around 30mph. In fact, while your driving, as you give it a little gas, the SES flashes and you feel the car hesitate, but you can't accelerate, rpm's don't raise.
I took the O2 sensor off and returned it to Autozone. My plan is to change the fuel filter/pressure regulator however, no part stores in town stock it.
Anybody have any other suggestions? I've already spent more money than my daughter can afford to pay.
Thanks
Old 11-25-2005, 09:55 PM
sickcallawayc12's Avatar
sickcallawayc12 sickcallawayc12 is offline
I would buy an o2 sensor directly from saturn at www.saturnparts.net just cuz the o2 sensor tends to be one of those "only get OEM" kind of parts. I don't think you need to mess with the fuel pressure regulator either. You should also post all the current codes that you have.
1998 Chevrolet Blazer LT (95% stock)
Pioneer AVH-P7500 DVD receiver
12" Alpine Type-R in a sealed box
PIAA Super Plasmas GT-X bulbs
PIAA Xtreme White bulbs
K & N drop-in filter
"Melo" and "AI". Enough said.
Old 11-25-2005, 10:31 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: SES light
To add the codes can not be cleared by a battery disconnect.
You need a scanner to clear codes.
Also a code does not say replace the sensor they say check it out.
A flashing light may point to a cylinder missfire.
As stated in upper check and post post back code no.
Then clear codes with a scanner and see idfany or what ones return.
What is the mileage on plugs and fuel filter?
MT
Old 11-26-2005, 01:50 PM
Re: Re: SES light
MT
Generally, if there is ANY issue with the o2 sensor, it's best to replace it. I also believe you may be experiencing a misfire. What brand spark plugs did you use? You should NOT be using platinum plugs of any kind most important. NGK v-power is the ones you SHOULD use.
Old 11-26-2005, 06:27 PM
Re: Re: Re: SES light
Thanks, I bought the O2 sensor, but checked the spark plugs before replacing it. Sure enough I had bought an installed platinum plugs about a month ago. Replaced them with the alternate and car runs great for the first time in months. Went back to Autozone, had them clear the codes although it still says bank one O2 sensor defective, light is still off, car runs, and I returned to O2 sensor again.
Thanks everyone
Craig
Old 11-26-2005, 09:10 PM
MT-2500's Avatar
AF - Advisor
Re: SES light
If the light does not come back on after code clear you do not have a problem.
A code or any code does not say the 02 sensor is defective.
What was the code no you had when they cleared it?
The code no would tell us a lot about what is going on.
Post back the code no and let us know if the light comes back on>
Also depending on the code it may need the EE prom reprogramming. And a 02 sensor replaced
There is a tsb on it.
MT
Old 11-26-2005, 11:21 PM
I'm sorry you had to spend a bunch of money for what was a simple probelm. Putting in platinum plugs is actually a common mistake people do to their saturns. Most of those thing that you did are good things to do to saturns anyway though so you should have years of faithful service from it.
Old 11-28-2005, 10:53 PM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
Re: SES light
with the exhaust manfold cold, remove the front O2 sensor, and test drive, if power increases. a clogged cat is possible, if so, and you have less then 80K miles, take it to saturn, it may be warrenty. do not drive with the O2 removed any more then is needed to diagnose, do not reinstalled the O2 with the Manifold hot.
Daily driver: 1995 Buick Regal Custom 3.8L 4T60-E 150K miles
Gone: 1994 Saturn SL2 1.9L MP3 168,666 miles
EPA 608 Universal Certification
EPA 609 Certification
