Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 11-22-2005, 11:50 AM
jaguar02 jaguar02 is offline
Trans acting up
1991 explorer with 135k miles on it. When cold starting I have to shift the trans 1. 2.then D only once, then into overdrive after 45 mph. If I drop below 35 mph with it in OD it just revs and goes no where and I need to put it back into D. I only use this thing in winter months so I can live with the shifting. I checked the fluid and it is not a bright red color but more of an orange color. Vacuum modulator looks ok and the vacuum line is connected. Any other things to check?
Old 11-25-2005, 08:41 PM
dorfboy dorfboy is offline
Send a message via ICQ to dorfboy Send a message via Yahoo to dorfboy
Re: Trans acting up
Sounds like the bands may need to be adjusted. I think you can get that done at a shop for a little more than $100
Old 11-26-2005, 07:40 AM
srercrcr srercrcr is offline
Re: Trans acting up
Has the fluid been flushed?
Old 11-26-2005, 09:35 AM
ixoxoli ixoxoli is offline
Send a message via AIM to ixoxoli
Re: Re: Trans acting up
I have heard from alot of mechanics that flusing trans fluid is very risky at that milage, they usually say that if it wasnt flushed prior to hitting 100K, dont flush, becuase you can do more demage then good.
Old 11-26-2005, 10:53 AM
Dr98 Dr98 is offline
I have read that flushing out high mileage vehicles will kill your trans on this forum somewhere. So follow that advice!
Dr98
Old 11-27-2005, 07:28 PM
steve11 steve11 is offline
Re: Trans acting up
dont have the thransmission "flushed" by a machine, but by all means, drop the pan, change the filter, clean out the crud, and add 5 new quarts of fluid. that could help the shifting. things may be worn inside, but you could have a little trash stuck in a valve. ---pressure flushing on a machine could loose up buildup that has centrifuged out and get it stuck inside the valve, drain and refill does not hurt, and very well could help.
Old 11-28-2005, 09:52 AM
Thanks for all the suggestions. I plan to change the fluid, filter and gasket this weekend and will post with results.
