92 Tracker Torque Converter No Lockup
I haven't had my 92 Tracker long, but I did notice it doesn't get
very good mileage and now that I've fixed some of the more major problems I'm trying to work on this one. I thought at first that the car must not have a lockup torque converter because I can tell it is still slipping at highway speeds and you never feel it lock up. But I've done some reading and it sounds like these should have a lockup converter, right? So now the question is, what would cause the converter to not lockup? BTW, the check engine light is on at the moment and I haven't been able to get it to blink a code for me yet......still working on that one.... |
Re: 92 Tracker Torque Converter No Lockup
how much mileage on the car the engine light comes on automatically at 30,000 60000 and so on
also do you have three speed or four mine revs at about 4000 rpm for 70 mph and gas mileage is about 23 to 25 if i baby the truck at 55 to 60 it get about 26 to 28 mpg.to turn off light look by left speaker under dash there is a on off switch. |
Re: Re: 92 Tracker Torque Converter No Lockup
Thanks for the help.......I'll try to post any progress I make. |
the torque converter is controled by the computer to my understanding in 89 to 94 they used a mitsubishi computer which is suppose to be inferior to mine the 95 which uses the suzuki computer. on mine there is a relay in engine compartment on the fender well coud check relay.
i usually go to the library and borrow their chilton manual helps alot. . |
It looks like power goes through a 15A fuse, then through a switch on the brake pedal, then to that relay, then to the transmision. I'll start trying to debug when I get a chance and post any results.... |
i checked it last night i rev 3000 to 3050 to go 55mph at 65 i rev about 3600.
Fixed Engine Light....started TC debug
Well I pulled the speaker and found the switch and got the check engine light off !! Thanks the the tip.
I also checked and I have power to the brake switch for the tc lockup...but didn't get any further......... |
it looks like the power for the relay comes from the ecm at a16 terminal then goes to the relay once activated the power to the clutch relay comes from the stop lamp switch so i would check the white/yellow wire to see if it has power once you get up to temperature and speed. i would put a light bulb 12v in line to see if the power from the ecm is coming on if it is the ecm should be ok then all you have left is the relay and if the relay is good then it could be inside tranny. you can check relay out of the car just put 12v pos on white and yellow connector and neg to the blu/black conector.and an ohm meter across the other two terminals to see if you got continuity
Thanks again for the help.
I've gotten as far as finding out that I have power from the brake switch to the relay....next step will be to see if I have power leaving the relay to the trans at crusing speed....I'll tap into the white wire leaving the relay and run it inside so I can check......I'll keep posting as I make progress. |
White wire to the trans has power once the car warms up a little, and it drops out when I tap the brake.
Next will be to crawl under the car and see if somebody disconnected the stuipid wire from the trans.....if its that easy I'll be pretty happy. |
![]() "doing that is like trying to sell porn to a 6 year old..... It's just wrong" - hypsi87 LE123456712: i promise i will stop filling your email with my boobs Kieft125: lol.. good, its starting to get rediculous.. |
on the 96 you have an obd 2 reader go to autozone if there is one around you they will read code for you and i think they can reset it sorrry no switch.
had it reset several times already.. it just keeps coming on.. i cant stand it.. im about to just put some electrical tape over where the light is
koatik can you get the code from the reader.
