Old 11-22-2005, 07:35 AM
jkdon jkdon is offline
bleeding brakes
Hey guys I just had to replace about 10 feet of brake line on my 97 LS 125K. I'm wondering if the truck needs to be running to bleed out the abs system or can I just start pumping and bleeding with it off?
thanks
Jkdon
Old 11-22-2005, 08:57 AM
billibong's Avatar
billibong billibong is offline
Re: bleeding brakes
You can just do a regular bleed. Start at the passenger rear wheel, then driver rear, passenger front then driver front. That way you are working from the farthest from the Master Cylinder to the closest. Hope this helps.
billibong
99 4X4 Blazer LS Vin W
Repairs:
U/L Ball Joints, I/O Tie Rod Ends, New Tie Rod Adjusting Sleeves, New Idler Arm, R & L Front Hubs, R & L Upper CA Bushings, New Gabriel Ultramax Shocks (what a difference)
F & R Brakes and Rotors at 110,000.
Infinity Speakers to replace the blown factory sets.
162K+ and still kicking.
