Old 11-22-2005, 07:10 AM
stevezaj stevezaj is offline
adhesive for flocking, what do you use?
Paint, white glue, something else? Has anyone used future floor wax?
Old 11-22-2005, 07:33 AM
gionc's Avatar
gionc gionc is offline
Authorized Vendor
Re: adhesive for flocking, what do you use?
fast(5min) white glue, so you could remove some excess in case...
gio
Old 11-22-2005, 07:41 AM
Vric's Avatar
Vric Vric is offline
Normal White glue.
Old 11-22-2005, 07:59 AM
ZoomZoomMX-5's Avatar
I use flat acrylic paint the same color as the flocking. Brush it in rapidly (in sections), dump in flocking, dump out excess by tapping it, and continue. You can use white glue or flat clear paint as well. It's pretty easy stuff to use.
My Fotki Album
Old 11-22-2005, 08:13 AM
mickbench's Avatar
mickbench mickbench is offline
I tend to use ordinary craft white glue. I normally do half of the tub first, apply flocking and press it down, then turn part upside down to remove access and if need be use a hairdryer (on a low setting) to dry the glue and blow the unwanted bits away.
Then repeat for the second half of the tub. And zoomzoom is right, paint the tub or whatever as close a colour as possible to the flocking being used.
It's dead easy to apply and the results always look good if done correctly. Works just as well with Enamel or whatever but if using white glue and you mess up, you can use water to wash it all away and try again.
Old 11-22-2005, 08:29 AM
Okiemodelbuilder Okiemodelbuilder is offline
I use Testors Acryl flat clear. That way I can paint it over any color and use any color flock without worry.
Completed Pro Touring Projects
...the pro touring experts
Old 11-22-2005, 12:15 PM
MoeSzyslak73 MoeSzyslak73 is offline
Elmer's white glue. It's one of the easiest mod and the result is always pleasant.
Old 11-22-2005, 02:03 PM
Lambo003's Avatar
Lambo003 Lambo003 is offline
A few years ago I started using just regular old automotive paint right from a spray can that closely matched the flocking .
Seems to hold up better during handling in final assembly. The water based glues and such have a tendency to scratch off fairly easily. . .
Chuck
Old 11-22-2005, 02:36 PM
klutz_100's Avatar
BAaed on my VAAAST experience (one flocking job), I've got to say that white glue works fine BTW that was dark grey flocking on a black base and no glue was visible afterwards.
Alex Kustov's "how to" on Italian Horses is A1 stuff.
