Go Back   Automotive Forums Car Chat > Ford > Mustang > Performance
Performance Discuss Engine, Suspension, Drivetrain, and all other performance modifications here.
Old 11-22-2005, 12:57 AM
Killa_DSM's Avatar
Killa_DSM Killa_DSM is offline
Thunderbird Supercharger on a v6 98 stang?
Hey whats up guys, my brother has a 98 v6 mustang and told me that he has heard that people have putting thunderbird superchargers on their v6 mustangs because they are the same engine? Well his question was is this true? What all do you need to this? How much work is involved? Are there any links to help us out?
Sorry for all the questions, thanks in advance!
"Life begins at 20psi"
97 Eclipse GST-X 5spd
PTE 5031e/pte 880cc/vr4 fuel pump/Devils Own Water injection 12gph nozzle/pre turbo meth injection/fmic 28x10.5x3.5/greddy type-s bov/12" K&N/FP intake/dsmlink/gm 3.3 bar/maft/blitz ebc/act 2600/act 6 puck/SS Clutch line/3" turboback.
Old 11-22-2005, 11:30 AM
neatofrito1618 neatofrito1618 is offline
Send a message via AIM to neatofrito1618 Send a message via Yahoo to neatofrito1618
Re: Thunderbird Supercharger on a v6 98 stang?
they have the same engine. but i dont know if u could put the same supercharger on them
Old 11-22-2005, 05:27 PM
mr_tw's Avatar
mr_tw mr_tw is offline
(this is just things you would need to check) you have the check compression ratio (most likely different) and the rods crank shaft is most likely the same the heads (this could cause the change in compression, or it could be done by the pistions (more likely) the funest way to do a swap like this would be to find a junker SC V6 and take a week off work and taer both apart and sawp it all over, but thwn you could just go to the net, save yourself some treouble and buy a supercharger kit easer and if it's from a good manufacturer will be a reliable part, and I'm sure many people could help you out with where to look
What Is With The Hatred Between Imports and Domestics? In The End, We All Love Cars.
Old 11-23-2005, 09:24 AM
Mines69Olds's Avatar
Mines69Olds Mines69Olds is offline
Send a message via AIM to Mines69Olds
I was at the junkyard a few weeks back and saw a 2 SC thunderbirds just sitting around. One was wrecked but the motor was still intact and looked good.
1969 Olds Cutlass
1985 Olds Cutlass
2000 Ford Ranger
2001 Jeep Cherokee Sport
Old 11-23-2005, 11:16 AM
Killa_DSM's Avatar
Ok thanks alot everyone!
Old 11-23-2005, 01:20 PM
Re: Re: Thunderbird Supercharger on a v6 98 stang?
u have a 455 in ur cutlass? i thought u had a 350?
Old 11-28-2005, 11:12 AM
Well I did have a 350 in my cutlass but right now it has nothing. I'm rebuilding the 350 and putting it in my 85' cutlass and have a 1968 455 that I'm going to rebuild and put into my 69' cutlass.
1969 Olds Cutlass
1985 Olds Cutlass
2000 Ford Ranger
Old 12-13-2005, 12:00 PM
Ghostang96 Ghostang96 is offline
the sc off the thunderbird will fit. you need the valve covers off the bird also to switch the oil fill to the other side. the thunderbird has a lower compression then a mustang so if you can get a bigger pulley on the sc to lower the boost. other than that the engines are nearly identical.
