Go Back   Automotive Forums Car Chat > Chrysler > General Discussion
Old 11-21-2005, 11:11 PM
fergy623 fergy623 is offline
Send a message via MSN to fergy623
Question ??? coolant sensors
Can anyone tell what the difference is is between the coolant sensors in any dodge or chrysler products as it seems they all have the same purpose but different part numbers? I have tested them all from 25 different chryco products and engine classes with no difference in readings or voltages as well as ohms. I have switched the sensors from various vehicles and there seems to be no difference in the operation of the engine or fuel economy, with the exception of the faulty sensors that I have tried. Does anyone have a view on this topic?
Old 11-21-2005, 11:15 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: ??? coolant sensors
on some older engines, they had a coolant temp gauge wire and a coolant temp sensor that worked to feed information with the engine computer. I'm guessing you are referring to the coolant temp sensor controlled by the engine. That sensor is a thermistor, meaning as the temp. is lower, the resistance is higher and when the temp is higher, the resistance is lower. As far as there being any difference, there really isn't, as long as it performs its basic function, it's doing it's job.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
