Old 11-21-2005, 11:03 PM
blisk323's Avatar
blisk323 blisk323 is offline
Engine wire harness problem
i've just finished my swap, i took out a D16Z6 and dropped in a JDM D15B Vtec, everything was a simple bolt on except for the engine wire harness. What can i do if i dont succeed in getting one can i use the D16 harness and modify it or do really need one from a 5th Gen. civic Vtec?
Old 11-21-2005, 11:16 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: Engine wire harness problem
i believe the z6 harness runs a 4 wire o2 sensor as the jdm d15b runs a 1 wire o2 sensor, other than that, the z6 should be fine. as for not running with the z6 harness, all you should have to do is run two wires for vtec.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 11-21-2005, 11:19 PM
blisk323's Avatar
ok, but the Z6 is non fuel injected, how do you use that harness with a fuel injected engine?
Old 11-21-2005, 11:36 PM
AF - Advisor
the z6 is fuel injected.
you had a d16z6 in what chassis? now you are dropping a d15b into what chassis?
Old 11-21-2005, 11:47 PM
blisk323's Avatar
im dropping it into a 91 Dx the Z6 is PMFI
Old 11-22-2005, 04:54 AM
CrxFreak91 CrxFreak91 is offline
o it aint fun i have done that once or twice. just run four new wires from the fuel injectors to the wires on the ecu. make sure you use the book. but the wires on the ecu read 1-whatever from left to right not up/down up/down
