Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 11-21-2005, 10:29 PM
thundermtx thundermtx is offline
Question 1999 Venture transmission
Just bought 99' Venture w/ 109K miles; experiencing hard shifts when accelerating slow or fast(after warming up). After reading some posts in this forum, can cleaning MAF sensor help, replacing fluid and filter, or soleniod in trans. be my problem?
Old 11-29-2005, 01:16 PM
neurottica neurottica is offline
Re: 1999 Venture transmission
i have the same problem. tranny flush doesnt solve this problem. let me know how you make out
Old 11-29-2005, 01:58 PM
cdru's Avatar
cdru cdru is offline
Solenoid problem would be the likely culprit. Cleaning the MAF sensor is easy to do, so you can start there but I wouldn't expect much.
Vinyl adds horsepower, right?
Old 06-01-2006, 10:27 PM
Question Re: 1999 Venture transmission
138K miles and after trans fluid change, NO CHANGE in jurking. Is solenoid easy to change and how much? MAF sensor cleaning didin't help.
Old 06-02-2006, 07:57 AM
cdru's Avatar
I have not done the procedure myself, but from what others have said, I beleive it requires removing the end cap of the transmission. This in turn requires to drop the transmission down (although possibly not completely out).
Old 06-02-2006, 10:00 AM
DRW1000 DRW1000 is offline
With 109K miles and a transimisssion that is acting up I would recommend changing the fluid and filter as a first step. Although it has been suggested by some that a fluid and filter change did not solve their problem your van is due in any event (assuming you do not know the history). You might get lucky and it may solve your issue but either way it should be done even if your transmission was not acting up.
I would recommend siphoning out as much fluid as you can from the fill tube prior to dropping the pan.
Old 06-02-2006, 03:13 PM
89ltd 89ltd is offline
if you checked for codes you would most likely get a P1870, if you search the forums and internet for that code you will find information on it. I believe its a faulty valve body.
Old 07-25-2007, 11:09 AM
billluk billluk is offline
Most likely it's the EPC (electronic pressure control) solenoid. The transmission has to be partially dropped to access the side pan. I have been quoted 5 to 6 hours labour plus the solenoid at a total cost of about $600.
Old 07-25-2007, 01:41 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
billluk- Please check the dates of the thread/last posting date and avoid posting in old threads. This one has been inactive for over a year. Check with AF's User Guidelines for more info.
Thread closed.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Closed Thread
