Old 11-21-2005, 07:59 PM
GTPWarrior's Avatar
GTPWarrior GTPWarrior is offline
Help asap
Just replaced the water pump on my 98 GTP and now the engine is smoking. What did I do wrong?
[b]1998 Pontiac Grand Prix GTP
"A man walks into a bar and says.....................*ouch*"[/b]
Old 11-22-2005, 05:44 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Help asap
When you say smoking what do you mean? Is it overheating and you are seeing steam or is there actual smoke coming from the engine?
To give you my best guess I would have to believe you have air in the cooling system and that is what is causing the problem. Remove the radiator cap and start the car. Once the thermostat opens you should see a drop in coolant level. This will be the coolant filling in where the air was. Refill as necessary.
If the smoke is coming from somewhere else please post again and we will try to assist.
Old 11-22-2005, 06:58 AM
GTPWarrior's Avatar
Re: Re: Help asap
This is smoke from the back side. Smells like somethings burning But temp guage isn't going up was afraid I might screw up the engine. Also thought I might just be burning something off the the front started to smoke a little. I will try to take the radiator cap off and see if this fixes the problem \. I believe that you have hit it right on the head, Thanks GTP DAD
Old 11-22-2005, 09:56 AM
GTPWarrior's Avatar
Re: Re: Help asap
Thanks once again GTP Dad The smoking stopped lot of air left over
Old 11-22-2005, 01:24 PM
kustomkid54's Avatar
kustomkid54 kustomkid54 is offline
Re: Re: Re: Help asap
For an old guy, he's pretty good isn't he?
